Question about The Computers & Internet
Is the hydro trans on an old 1995 Kubota T140 sealed?
Should read T1460
Is the hydrostatic transmission on an old (1995) T1460 sealed?
if it has adipstick hole then-- no
if there is no dipstick hole then-- yes
May 12, 2017 | Garden
Forward and reverse appear to be getting slower
hydro drives have a habit of failing
There is a requirement to change the oil on a regular basis so it is possible that the viscosity is changing from contaminants and
best talk with your local Kubota service dealer and see if there is a problem other than oil
Nov 13, 2015 | Garden
How many horsepower does a kubota tractor B8200 has / what year was it made
It was made between 1983 and 1990
Kubota B8200 Power:
Engine (gross): 19 hp [14.2 kW]
PTO (claimed): 16 hp [11.9 kW] (gear)
14.5 hp [10.8 kW] (hydro)
You can find more breathtaking information about this tractor at
Apr 29, 2015 | Kubota Garden
Kubota T 1460 Need belt size for deck and belt going to Engine
kUBOTA FOR T1460 SN 40001 AND UP
K5112-71410 DECK BELT
K5112-51310 ENGINE TO DECK
Cross reference shows both to be 5/8 x 69 Kevlar belts
Apr 17, 2015 | Kubota Garden
Kubota wont move
sound like hydro pump is out did you try change filter ail on hydro
Aug 27, 2014 | Garden
Massey Ferguson (simplicity) 2516 hydro tuff trac trans. Moves good for 1/2 hour then loses ability to move fwd or back at any speed. Eventually loses the ability to reverse completely but will move...
you have a problem in the hydro unit. probably a broken seal that is allowing oil under pressure to escape and build up temp in the unit Suggest you have a massey mechanic inspect and advise the exact cause as it will not be a one off problem
Jun 02, 2013 | Garden
T140 Triumph 750 Bonneville Oil Pressure
Before listening to the doom merchants try this first. Make sure the oil seal in the timing case (not points cover - the crankshaft one) is the right way round (spring side showing) and seated OK. When fitting case oil up the seal well and turn engine over (plugs out) while tapping the case home gently with your fist - if this seal is not dead right it will alow enough oil passed it to throw the pressure switch open without causing any damage. Had my T140 32 years.
Jul 15, 2009 | 2004 Yamaha V Star Classic
Need to change hydro fluid, what sould I use
is it a Massy?
Do not use eng oil!!!
Kubota UDT, Case IH hy-tran ultra oils will work on most.
Apr 10, 2009 | Puzzle Massey Ferguson Tractor
Oil leaking from rear main seal, how hard is this to change. And whats the going rate for a shop to do the repair.
Replacing the rear main seal is kind of a long one. It involves seperating the motor and trans. Depending if it is manual or auto,would weather you have to remove the flex plate (auto trans) or fly wheel (manual trans). Then of course there is removing the old seal, making sure it is free of burrs and putting the new one in, and reassembly.
Mar 28, 2009 | 1995 Toyota 4Runner
Computers & Internet Logo
47 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
