Question about HP iPAQ RX5915 Travel Companion GPS Receiver
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can recognize it. Reset button restarts it, just freezes at the blue and white HP pocket PC screen - no other buttons will do anything. (Version is 1.00.04) Took the battery out and back in (only way to power it down right now), but it advances to that same point and freezes.
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Posted on Aug 15, 2009
I haw a ipaq but my newsdhc 4gb do not want to install.
This HP Ipaq runs on Windows 5.0 , which is an old platform. For 4GB SDHC to work u will require an advanced handset. Even if it accepts it will freeze or the screen will stop working. Finally u cant install 4GB SDHC on ur HP IPaq :(
Mar 14, 2011 | HP iPAQ HX2100 Pocket PC
How do i get a new start up disc for a hp ipaq hx 2400?
Microsoft Windows for Pocket PC 2003 is the software on your hp ipaq hx,
Here is the link for it:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9996b314-0364-4623-9ede-0b5fbb133652
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 08, 2010 | HP iPAQ HX2400 Pocket PC
My hp ipaq 3950 freezed
press reset button with your stylus or take out the battery for a couple of minutes, put it back in and power on the device
Aug 21, 2009 | HP iPAQ H2210 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
HP Ipaq 2910 wont finish the boot
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Sep 01, 2008 | HP iPAQ H2210 Pocket PC
Will not start up after recharging the battery
Hello :-) I think that your battery is causing the problem. You might have charged you ipaq to many times with a cheap battery and the battery might be completely dead. Or the battery might just be defective.
Apr 12, 2008 | HP iPAQ H2210 Pocket PC
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
If still freeze after the resets, then try to do a Hard Reset.
With this way you will restore your device at the default condition.
Take care to remove any external memory from iPAQ before to this and also have it
full charged.
The bad of this....you will loose everything stored at the internal memory of iPAQ.
The good this...your iPAQ would be alive again ;-)
To to a Hard Reset press at the same time the reset button+calendar button+today button.
Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
HP iPAQ RX5915 Travel Companion GPS Receiver Logo
467 people viewed this question
Top HP GPS Experts
Will Halftowaite
Are you a HP GPS Expert? Answer questions, earn points and help others
