Question about Miscellaneous
Microwave loud buzzing noise
JVM3660SD
    Top Expert:
  • 3,107 Answers
I suggest calling in a repairman.
Posted on Jun 01, 2017
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
LOUD BUZZING NOISE AND THE ANSWER I RECEIVED WAS FOR A DIFFERENT MODEL. CAN I FIX IT MYSELF?
If the loud buzzing noise is present when cooking food, the magnetron is the likely cause, some models are louder than others. But if the buzzing noise is there without the microwave running it should be checked. No! this something that should be checked by a professional for safety.
Mar 17, 2012 | GE Monogram ZEM200SF Microwave Oven
Whirlpool microwave makes loud buzzing noise
When your microwave oven won't cook your food, and, you hear a loud buzzing sound, it’s normally caused by a faulty (a) diode (b) high-voltage capacitor (b) magnetron.
The diode would be the most likely culprit of the three components. It’s also by far the cheapest!
Sep 21, 2009 | Whirlpool MH6140XK Microwave Oven
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Miscellaneous Logo
14 people viewed this question
Top Miscellaneous Experts
Charles Blake
Charles Blake
Level 1 Expert
Leslie Rowe
Level 1 Expert
Scott Tumath
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
