Most TVs don't have a built-in satellite receiver. You'll need to buy and install a suitable satellite receiver box for the signals that your dish is capable of receiving. The dish connects to the satellite receiver. Then the sat receiver connects to the TV via either AV cables or HDMI. Hope this helps.
Hi Meagan, my name is Cheri Torres and I work with DISH Network Internet
Response Team. I came across your post and wanted to see if I could
help. Connecting your TV to your DISH Network receiver should be
fairly easy, depending on the connections you are using. If you are
using an HDMI cable you will need to connect one side of it to your TV and the other end into your DISH receiver, as long as you have an HD
receiver. If you do not have an HD receiver you are probably going to
want to use composite cables(red, white and yellow). If you are using
either of these cables you are going to have to set your TV to an input
in order to receive the DISH picture. You can select an input by finding
a button on the TV remote or the TV itself that is listed as input,
source, AUX, mode or video. You will need to cycle through each one
until you find the DISH picture on one of them. Once you have the
picture you will need to press SAT on your DISH remote and everything
should be working fine from there. I hope this information is useful and
if you have further questions feel free to ask!
Of course it is important to make all connections right, and I assume, since you have sound, that you did all the wiring OK. But also important is to orientate very precisely the sat dish. In order to do so you need some devices and skills. Better ask a local professional to do that.
I am assuming when you say you disconnected power from the TV to install carpet, you disconnected the cables from the receiver to your TV. Depending upon your installation, you have a cable that comes from the dish located outside that is connected to a splitter and has 2 cables coming off the splitter. The 2 cables will connect to SAT 1 and SAT 2 on the back of the receiver. Your TV 2 connection either goes directly to your TV 2 or goes to a second separator, connected to the UHF/VHF connector. If you still have problems with the connections, please email me at [email protected] and I will assist you further.
Heychuck68102, my name is Mike Houston of DISH Network and I was going over yourpost and I see where you want to connect a cable wire plus you're satellite. Ifyou have a TV that will allow for a RCA connection you can run the RCA cable tothe top red, white and yellow inputs and run the antenna directly to theTV/Antenna IN. Then you will be able to connect the cable to the TV CH ¾ input.I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/how-to-set-up.
Hey my nameis Mike Houston of DISH Network and I see there is a problem with the Sony hometheater system connecting with the DISH receiver. To get the full surroundsound you want there are two different options you can use, the first is to usethe HDMI and connect the RCA cable or you can use the Optical cable for sound.If you have any questions or concerns please e-mail me back; [email protected].
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
