Question about Dometic Heating & Cooling
Is it common for a rv rooftop air conditioner to leak water on to the roof? I have a Dometic Duo-Therm unit 579,590,595 series.
    Top Expert:
  • Dometic Master
  • 80,668 Answers
All AC units create condensation from the cooling of air (cold/cool air hold less water than warm air), it is worse in areas of humid air like the Midwest for example.
Posted on May 12, 2017
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
R we still talking about the duo therm briskair roof &celing conditioner with no place to put the freeon mamawwyatt122142@aol.com
There are usaully no places to refill Rv Ac units. You have to have very particular parts to fill most units..Tell me your exact Issue..
Aug 05, 2010 | Dometic Rooftop RV Air Conditioner
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Aug 05, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
