Question about Cell Phones
Radio will not come back on after using the phone
Can anyone tell me how to get a radio code for a ford transit radio model 4000rds, serial no. M084765
Hi,you normaly have to phone the main dealer who have all the codes,but they charge.
Oct 12, 2015 | Ford Cars & Trucks
Cdma convert gsm
the phone has to have the necessary radio technology to use on weither. Unless the phone has dual radio (CMDA/GSM) antenna built in, it cannot be cross compatible. GSM phones can only be used on GSM networks. Its similar to why 3G phone without 4G capability cannot use 4G speeds. Also 4G WiMAX phones, can not use 4G LTE networks.
Tthe back end technology limits the front end usage. You can find cheap dual radio phones on EBAY, and there are lots of replica phones out there which have these technologies available in unlocked phones. You just have to be patient and look for a good vendor, and wait a bit longer for shipping.
Jan 05, 2014 | HTC EVO 4G Smartphone
Fiat 500c stuck in "phone"mode. How do I reset so the audio works?
With the key off, remove the radio fuse from the fuse box, start the car (there should be no power to the radio if you got the right fuse pulled), turn turn the car off, then then put the fuse back in. That should reset it.
In my 2013 Fiat 500 it's the 3rd fuse up from the bottom, on the left side of the bus. 10amp, red fuse. (If you're unsure, use the web to look up a map of the fuses for your make\model\year. Don't justt start unplugging fuses... you may strand yourself.) -Good Luck!
Jun 05, 2013 | 2012 Fiat 500
Optus won't accept my unlocked telstra samsung sgh-a412, why?
Contact OPTUS Email 1-800-383-368 Number For Technical Support
In Case You have any Difficulty while using OPTUS Email then Call Help Desk Australia.
OPTUS existing Email Service in Australian Region. It links Users from widespread. We recommend round a clock Support with my licensed Specialists. Our Team is Forceful and they provide support to the clients at no time. They offer high-class service.
Have Any Difficulty in OPTUS Email?
1. Troubleshoot
2. Configuration Errors
3. Sent and Receive Email Problems
4. Unwanted mail in Inbox
So, These Issues are happening in OPTUS Email. Our main objective is to offer High-quality service to our Consumers. We give Instantaneous Reply Service to the consumers through Phone Number. We have well Qualified specialist which provide 365 Days Support to the consumers. If you have any difficulty then Phone up OPTUS Email Technical Support Phone Number Australia For Quick Support.
1-800-383-368
https://www.helpdeskaustralia.com/optus-technical-support.html
May 25, 2017 | Computers & Internet
Radio code for renault meganne 2000
Each code is individual to the serial number of the radio. There is no standard master code for this radio. You will need to remove the radio to find its serial number on a label at the back.
For radio codes for Renault and many other models I can recommend this site.
Just enter the serial details and you will have your code sent right back to your email or mobile phone. Use them regularly for radios that I repair and can confidently recommend them.
Thanks for using FixYa.
Aug 24, 2011 | 2000 Renault 181
I have samsung b3410. cannot remove the fm radio off screen
Hi, sometimes when the a radio is corrupted it does that a lot, the only way to get that off the screen is to Flashing the phone memory for it to restore back to normal.
You can use this link below to do that.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | Cell Phones
Change radio station on Panasonic KX-T7633
Well, it depends. You can have 2 BGM sources on a TDA-100 or higher system. The system in the back room will have 2 MOH jacks and you can select the source from a phone. Since this is also the Music that the callers hear, there may be copywrite issues on playing commercial radio on hold. Most places actually use MOH 1 for a Promotion on hold, and MOH 2 for employee's BGM.
Carl
Apr 28, 2010 | Panasonic KX-T7633 Corded Phone
The radio on my phone wont' turn on
If the radio won't turn on it generally means it is not within coverage or the phone's account is deactivated. Take the battery out and leave out for 2 minutes. Put the battery back in and the radio should come back on. If it does not then go through the menu to bring the radio back online.
You can also try this:
https://www.wireless.att.com/support_static_files/KB/KB37092.html
These phones are also known to have issues if the sound is turned on for some reason, try turning the sound off and back on.
Oct 19, 2009 | Palm Treo 650 Handheld
Reset sciphone i68 to factory settings, now it won't do anything
I also have the same problem. I took the battery out and put it back again. I could unlock the phone. But everything in the phone is messed up. The "setting" icon is for radio, the "radio" icon is for "setting", etc.
Jul 21, 2009 | Cell Phones
Hands Free Link problem on my 2004 Acura TL
Heard a similar complaint, try disconnecting the main battery leads. This should clear the head unit and allow you to return to default menu.
Dec 27, 2008 | 2004 Acura TL
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
