Question about Honda Electrical Supplies
What type of fuel should I use in an ed250 Honda generator
After reffitting fuel tank & fuel lines, how do i bleed fuel system on Honda Prelude 5th generation 1999 model. Thankyou for your help.
-Here some basic.
-Turn the key to on and off couple time. (Do not start).
That all.
Good luck
Mai
Nov 23, 2016 | 1999 Honda Prelude
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
When my generator is off, the gas from the tank slowly mixes with the oil, this might take a few days, the float in the carb seems to be fine..... i just don't get it
hi there
this is called wet sumping !
sounds like you may need to replace the fuel needle valve and seat if its replaceable
if the float is plastic the fuel level may not adjustable
your worst case cenario is replacing the carb ? if you cannot get replacement parts
but try
http://www.ereplacementparts.com/honda-parts-c-37657.html
type in your honda model off your engine block or plate
then go to the correct page for fuel system then order parts as needed
give it a try
cheers hope this helps pauly46
Apr 17, 2011 | Honda Electrical Supplies
I have a Honda 7000 generator. Engine will not start. Spark plug is clean and getting spark. Carburetor is clean. Float is free, needle is free. The fuel however is NOT getting from carburetor to cylinder....
If the generator is an auto stop/start type for standby use, it would seem those solenoids are the reason why fuel isn't getting through. It would be a fairly sensible method of stopping the engine remotely.
An auto start/stop generator would need a battery for starting purposes, a battery that would presumably also provide current to energise those solenoids and allow fuel to flow.
I suggest you refer to the instruction manual in the first instance...
May 27, 2017 | Honda Electrical Supplies
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Gas in the oil on my honda generator
Your needle/float is stuck, which will allow fuel to flow though the intake...past the piston..and into the crankcase. If has been awhile since you used it, most likely the gas has gummed up the insides of the carb. Otherwise, you may have had something get into the fuel bowl that is keeping the needle from closing. Best way to solve is to remove and clean the carb. Replace fuel filter if needed also.
Hope this helps
Mar 11, 2009 | Honda 3000 Watt Portable Generator
Fuel not getting through the carburator
Take off the fuel filler cap. On some this is the fuel tank vent.
If the vent is blocked the petrol flow will be suspended by the vacuum.
Steve
Jan 10, 2009 | Honda Electrical Supplies
Electrical Supplies Logo
64 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
