Previous question papers and solutions for Economics1
    Master:
  • Office Equip... Master
  • 923 Answers
Why are asking about previous question papers and solutions for Economics1? Are you a cheater when it comes to education? Do you think you will be able to do that if and when you get a JOB?
Posted on May 12, 2017
Testimonial: "no im not a cheater im looking for the previous question papers and solutions to prepare myself"
  • solver2010 May 12, 2017
    I suppose you know, that it's the same thing. What opportunity would you have for such at a job, when a NEW problem arrived on the scene, which had never been encountered before?
Borderless prints on A5 size printing paper.
Epson is the maker and you should follow their lead.
Apr 04, 2014 | Epson Stylus Office Equipment & Supplies
Computer says paper jammed but i can't see or notice paper jammed.
I have the exact same problem! Think it started after installing Windows 8. I have installed other firmware onto the printer previously to use refilled cartridges. Have you fixed this problem yet, please post a solution if you have one.
Feb 12, 2012 | Samsung Office Equipment & Supplies
I hav3 hp 1005 printer and its continuously jamming papers..pls tell me solution of this problem
The paper jamb could be caused by dirty or sticky rollers or failure to remove all traces of paper from a previous paper jamb.
Check for tiny pieces of paper in the printer, remove these pieces of paper.
Try cleaning the rollers with methylated spirits.
Apr 29, 2011 | HP LASERJET P1005 Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
1720dn error light will not reset
Follow this link to a previous FixYa post about this error and the suggested solution.
Feb 23, 2009 | Dell 1720dn Laser Printer
I purchased a C6280 all-in-one printer on 7-2-08.  Iwould like to know how do I print 5x7 and 8x10 photoson an 8x10 photo paper.  I can not find out how to do it looking through the manual. ...
We neeed to manually set the size of the paper in order to print on abaove paper sizes.
Open the HP Solution Center and click on settings >> print settings >> printer settings.
Now select the paper type as plain paper and click OK.
Now click on custom settings and enter the size of the paper and give it a name and click OK.
Now close the solution center and reopen it again.
Now click on settings >> print settings >> printer settings.
Now check whether we have the name that we gave to the custom size previously. Select it and then click OK and then try to print.
Jul 04, 2008 | HP Office Equipment & Supplies
The paper is constantly getting jammed in my hp psc 1510 printer
Ok...possible problems and solutions:
1. Most likely there is a small particle of paper still in the path which continues to pick at one of the new pieces of paper's edges and causing the new jam. Solution: check every crevice of the paper path for small bits of paper and remove.
2. the paper is too light for this printer. Cheaper paper is lighter in weight and typically will "ball up" easier with the action of the print head accross the sheets. This is why you souldn't use "copier paper" in your HP inkjet printers but it might be alright for the laser ones.
3. a previous jam has damaged (bent) one of the precision guides or parts in the paper path. Solution: buy a new printer.
4. the paper is too thick for this printer...(doubt this is the case but thought I would mention it) Solution: use lighter weight paper.
Jun 22, 2008 | HP Office Equipment & Supplies
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
k24674
