Question about Sony KP-57WS510 57" Rear Projection HDTV
Manual convergence adjustment does not change picture
  • 10,594 Answers
If Convergence Out section does not work then manual convergence can not be adjusted.
Please check convergence out ICs that might got bad and requires replacement.
To provide you more technical info, please intimate exact model of your Sony TV.
Thanks.
Posted on Jul 25, 2009
Color is off with double image?
Is the image bow-tie shaped, with red, green or blue fringing effects? If so, one of your convergence amplifiers has gone bad. (Bow-tie: at least one of the three primary colors in the picture goes out to the corners, but the top, bottom and sides are bowed in at the center.)
If it is simple color fringing, with no color grossly misplaced, something has messed up the convergence. This may be caused by a strong magnet near the set (for example, a poorly shielded audio speaker), moving the set so its orientation in the geomagnetic field is altered or its components mechanically shifted (rough handling).
If a convergence amplifier is bad, replace it before doing anything else. If you just have minor fringing, see your owner's manual for instructions on using the remote control to adjust convergence. If it isn't in the owner's manual, you'll need the service manual. Caution: if you try to adjust convergence with a failed convergence amplifier, not only will it not help, but you will have a lot of extra work trying to get it back to normal after you replace the amplifier. Try a small adjustment along one edge of the picture. If one or more of the selected color dots in the convergence pattern won't move, and you are sure you are following adjustment directions, stop immediately and proceed with hardware repair.
Convergence amplifiers are usually marked STK392-nnn where nnn is a specific variant number. Two are used; I usually change both because quite a few people have changed one and had the other die not long afterwards. Sometimes there is a fuse in the power feed to these modules that is also blown. If you change the fuse without replacing the amplifiers, you'll probably waste a new fuse.
Oct 06, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
MANUAL CONVERGANCE R56W28 ZENIETH
You have to use the remote - goto your convergence menu. If you can't adjust it - its broke - and needs to be fixed...
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Televison & Video
Cannot line up colors
Ur convergence it dead.Must change convergence ICS and all it resistors.Buy a convergence kit at Tv repair World.com,Tv repairkits.com to repair it ur self.If u know how to solders?Shop will cost U $300 for parts and labors.
Jan 23, 2010 | Televison & Video
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
Where to adjust convergence? Picture alignment...
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man download the instruction manual here. check page 28 for convergence instructions. or request the complete service manual from me at computec40@hotmail.com
Nov 22, 2009 | Sony KP-53HS10 TV
Projectors need to be adjusted i guess they moved when TV was transported
do not move crts manually. go into the menu and adjust the picture's convergence.
Jun 18, 2009 | RCA P61960 61" Rear Projection Television
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Dark picture and greener than normal
hmmm curious why you would adjust convergance to adjust a dark picture?press menu button on remote and scroll down
are you have convergance problems?
convergance amp ic are know to go bad with this set.
Dec 17, 2007 | Toshiba 53H71 53 in. Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
