Input 1,2,3 output 5,9,13 - Audio Players & Recorders
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    In the invers variation function, what happens to the output when the functions input is multiplied by 3?
    From y=k/x one gets y*x=k =constant.
    If you multiply the input x by 3 what happens to y?
    Let us call x' the new input value, and y' the corresponding output value. Then
    x'*y'=k
    Substitute 3x for x' and solve for y'
    (3x)*y'=k thus y'=1/(3x)=(1/3)*(1/x),
    But 1/x is the old output value y. y'=(1/3)*y
    Conclusion
    When you multiply the input by 3, the output is DIVIDED by 3, so as to maintain the product (input*output) equal to the constant k
    Sep 10, 2014 | Office Equipment & Supplies
    Wiring diagram for powerstat type 116
    Note this is a variable autotransformer. It is NOT ground isolated.
    1 - common for input and output
    3 - output (wiper)
    4 - 1:1 input
    2 - steps up input (max out is 132 vac)
    5 - steps up even higher
    Don Williams, Palm Bay, FL retired electrical engineer
    Sep 07, 2012 | Heating & Cooling
    Does my tv have audio outputs?
    42PG20 Connections
    • Connector Type
    • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
    • 1 x S-Video input ( 4 pin mini-DIN ) -
    • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
    • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
    • 1 x Serial ( 9 pin D-Sub ) - Rear ,
    • 2 x Component video input ( RCA phono x 3 ) - Rear ,
    • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
    • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
    • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
    • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
    • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
    • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
    42PG20 Audio System
    • Sound Output Mode Stereo
    • Surround Mode Yes
    • Sound Effects SRS TruSurround XT
    • Audio Controls Bass , Treble , Balance , Sound mode
    • Speakers Included 2 speakers
    • Output Power / Total 20 Watt
    • Additional Features Auto volume adjustment
    • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
    Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
    I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
    LG documentation states:
    When you use SIMPLINK function, you have to
    connect to the OPTICAL IN 1 jack to enjoy TV
    sound to your speaker system.
    Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
    If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
    My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
    so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
    Jan 11, 2011 | LG LHB335 Theater System
    I need the wiring colour codes for 2002 santa fe car stereo
    Basically the wiring of the large harness corresponds to the pins like this.
    Starting in the upper right hand corner and working down the right side from A12 down to A1.
    1=Left rear output-red
    2=Left rear output-blue
    3=Right rear output-black
    4=Right rear output-yellow
    5=empty
    6=Left front input-black
    7=Left front input-yellow
    8=Left rear input-orange
    9=Left rear input-green
    10=Amp 'ON'-blue&orange
    11=empty
    12=Amp sensor-black&orange
    Back up to upper left hand corner on the large plug
    13=Right front tweeter output-red
    14=Right front tweeter output-blue
    15=Left front tweet output-red
    16=Left front tweeter output-blue
    17=empty
    18=Right front input-red
    19=Right front input-white
    20=Right rear input-blue
    21=Right rear input-red
    23=Right front sub (+) output-yellow
    24=Right front sub (-) output-black
    The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
    1=Memory Power-Lrg White
    2=Amp Ground- Lrg Black
    3=Left front sub (+)output-yellow
    4=Left front sub (-) output-black
    5=Left front mid (+) output-white
    6=Left front mid (-) output-brown
    7=Right front mid (-)output-brown
    8=Right front mid (+) output-white
    Hope this will help you.
    Thank you
    Jan 04, 2011 | 2002 Hyundai Santa Fe
    How to connect mixer to a crown power base 2 amp and speakers
    just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
    Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
    Does this system have a optical input
    Here are the list of connections on this system
    • Audio inputs/outputs 2 analogue input sources,
    1 analogue output connection
    - TV : in
    - VCR : in
    - CDR : out
    - Headphone : 3.5 mm
    • Digital audio in/output : 2 digital output connection
    (coax, optical)
    • Video outputs : 3 output connections (1 S-Video)
    - TV : out
    - VCR : out
    - Monitor : out
    • Speaker Connections suitable for speakers ≥ 6 Ohm
    - left, right, center : click-fit connection
    - rear left, right : click-fit connection
    • Miscellaneous connections
    - TV center speakers pre-out : 1
    - Subwoofer pre-out : 1
    - AM antenna : loop type
    - FM antenna : coax
    please mark this fixya if it has answered your question.
    Dec 14, 2009 | Philips LX3000D System
    How do I know which converter box to buy?
    here are the specs for the Magnavox TB100MW9
    Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
    Jan 04, 2009 | Televison & Video
    Dear wayne,
    Please locate audio input socket on your TV, Then Connect audio output of DVD recorder to this input socket. The optical output of TV goes to input of amp. Since the DVD recorder is connected to the TV and TV's out put connected to the Amp. Now the sound signals from tv and as well from DVD will be 5.1 surround from the amp.
    If any case this does not solve your problem, please mail me the photo of the back side of TV's connections at my mail.
    rkr847@gmail.com
    ramesh22
    Jun 18, 2008 | Televison & Video
    14 people viewed this question
     Grubhead
    Grubhead
