0E code is showing on my washer and I can't find my owners manual.
  • 1,830 Answers
What brand of washer is it?
Posted on May 12, 2017
  • Washing Mach... Master
  • 2,950 Answers
If you do not get a better answer, this may help you.
For such problems I have, I look up and write down the make and model of the machine, then I type "Sears Parts Direct" into my computer search engine.
When the Sears site comes up, telling them the make & model information should get you at picture ( or several ) of that machine, and you should be able to order an owner's manual.
God bless your efforts.
F21 ERROR CODE
It would help to know what brand and model of washer you have. Often you can erase those codes by unplugging the washer and replugging it. AT that point the door may unlock.
Otherwise you can google the error code and the washer model and see what comes up.
You can even read the owner's manual. It ?ƒten has good information in it.
Mar 02, 2017 | Washing Machines
Have a samsung washer model WA17XAR showing OE code and makes grinding sound and does not start
Hi this is a link to a short youtube video showing error code 0E, This washing starts and stops as well and the guy fixes it.....CHEERS..
https://www.youtube.com/watch?v=YOvFYcaLp8w
Mar 18, 2016 | Samsung Washing Machines
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
My Samsung front loader is taking in water and flashing 0E. Can you help tell me what my problem is? Thanks
An OE code (not 0E) is an overflow error. Too much washing powder/liquid may have been added. Turn off power, wait 30 seconds and turn on power again. You should hear the drain pump operate to drain the machine.
Feb 22, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
Kenmore Elite He washer code "OE"
The 0E code means the washer won't drain. It is usually a problem with something obstructing the pump, a kink in the drain line or the pump is burned out.
Jul 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have an lg wd12650tp and it has stopped full of water with the code OE showing. I've tried emptying the filter at the front but it still wont drain? Any suggestions? btw apparently the code means...
Hi.
Error 0E is drain error.
Access the drain pump, located behind the service door at the base of the machine, in the front side, right below the washer door.
Disconnect power before starting the procedure.
Open the door and undo the pump attachment. Have a container ready to collect a good amount of water.
If that does not fix the problem, then there may be a fault. Further blockage, faulty pressure switch and faulty drain pump are the faults that can trigger error code 0E.
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Please click here to read an article showing how to fix common drain problems.
Regards.
Oct 21, 2011 | Washing Machines
LG washer has an error code 0E. Any suggestions/
its a drain error not fully drained within 10 mins
Oct 26, 2010 | LG WM-2277HW Front Load Washer
Maytag-Neptune stopped part way though cycle. Error code 0E shows on LCD panel. Powering down does not reset. I can't enter service mode as described in the washer manual the 0E code remains.
In general this error code is the main control.
Resetting by pulling out the plug may help, but I wouldn't count on it.
This would require a new main control board.
May 14, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
