I cannot run my cd - Computers & Internet
How to install microsoft office in my pc
Hi, You should the Microsoft Office CD. Close all running programs on your computer the insert the CD software to your CD Rom. The auto play will run your CD, if it is not run your CD rom manually. Follow the steps and guide on your screen till it completed. Note you wil prompted wit h CD keys during process ( find on cover of your CD software the CD key).
Jan 18, 2011 | Microsoft Office Professional 2007 Full...
If you have a problem using a cd (if it loads slowly and if it yakes a long time to runs the programs) I would recommend to copy the whole cd on to the hard disk and install or run from there. If you have nero then copy the cd to a cd image so that the cd image will run like a normal cd!
If this doesn't copy even then maybe the cd is dirty so try to clean it under a low power water current and use a bit of soap and then wipe thoroughly with a soft towel(hard towels can scrap the cd) and after making sure there is no water drops you can use the cd!
on Apr 30, 2008 | Microsoft Windows XP Professional
The CD for windows does not work with windows 7
You probably do not have a DVD drive. You cannot Run a DVD in a CD drive but you can run a CD in a DVD drive. This a huge advantage of the DVD drive over CD drive. The Windows 7 should be on a DVD which will not run in a CD player.
I hope your problem is solved.
Aug 20, 2010 | Computers & Internet
No, it will not run any cd-changer, if the model number has a letter "p" before the number then it will run a Pioneer CD Changer.
Dec 07, 2009 | Pioneer DEH-2100 CD Player
CD drive not reading office 2007
That happens to me all the time,just shut it down for 24hours and try agian.Let it autoplay
Sep 21, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
Can't run cd-r disc
Specifically some units will run cd-r some will run cd+r whereas others will run cd+/-r
Before purchasing specific discs you need to know which type are compatible with you model.
May 08, 2009 | Computers & Internet
Cd is not running the program
If cd is running properly then there are no issues. If program is not running which is present in cd then that cd may have corrupted. or Please login to administrator account and run the program. Hopefully it should work.. Thank you...
Sep 12, 2008 | Computers & Internet
Setup CD
hi if it wont run when inserted . you could try doing the following .
click start
run .
look in click the drop down folder
select the cd drive with the cd in and click on that see if that helps run the cd.
failing that i would download the driver from the makers web site and update it .
Nov 20, 2007 | Garmin StreetPilot i3 GPS Receiver
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
