Question about Roku Televison & Video
I'm getting nothing from my Roku player it says no signal
Just hooked up the streaming stick to HDMI to the TV. nothing is showing up, What do I do now?
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Feb 25, 2016 | Roku Streaming Stick HDMI Version
Unable to connect to roku screen is a graphic picture of a winter scene
Do you have an Internet connection? Needs to be close to router to receive WiFi signal. Would have had to login in to service account on Roku device to get NetFlixs
Dec 16, 2014 | Roku HD Player (N1100)
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
Low wireless signal
it depends on your location. Try to move the Roku player closer to your router's location. Remove all possible obstacle
Feb 17, 2014 | Roku LT
Www roku com support
Roku gets its signal from your wireless router. If your internet is down so is your roku. If it is ok then go to the setup menu on the roku and try reconnecting to the router.
Jan 28, 2014 | Televison & Video
Ican not get signal from my roku
**You can skip this if your Roku player is wired to your router with an Ethernet cable.
If you are connected using wireless networking, check that the signal strength is at least "good".
To check your wireless signal:
1. From the Home screen, go to Settings>network and see what is displayed for "Signal strength"
2. If it is "good" or "excellent" you should be all set
3. If it is "fair" or "poor", follow the next steps
4. Move the placement of your Roku player and/or your wireless router to improve the signal quality
- The Roku player should not be recessed within a media cabinet, instead it should exposed in the open if possible
- Try changing the direction the Roku player faces, you may have to experiment with various spots for optimal signal
5. Run repeat guided setup and note the dark bands above your wireless router name. This gives a visual indication of the signal quality.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Dec 18, 2012 | Computers & Internet
My roku will drop the program while watching a movie
Sounds to me that your Roku is losing signal to the Router or hotspot. Try setting the router at least 5 feet away from the Roku Box and the higher the router is in the house, the better signal for all devices. Wi-fi broadcast down easier than up!
Jan 31, 2012 | Roku Televison & Video
Televison & Video Logo
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
