Question about Salter Health & Beauty
Salter high precision stainless scale 1078ss. How do i get it to weigh ounces
    Master:
  • 923 Answers
Put the weight on the scale. It should weigh ounces, pounds, grams, and killograms, all in the same unit.
Posted on May 12, 2017
How to reset as scales are not weighing properly and new batteries have been inserted
These scales cannot be calibrated so i'm afraid that it's time for a new set. I think they were first manufactured in 2002 and they have a 10 year guarantee which meas you are out of luck. If you are in the UK, this site is a good place to start looking for another set of All Kitchen Scales
Jan 23, 2014 | Taylor Salter 1010 Stainless Steel...
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process.
Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
Jan 21, 2014 | Salter Stainless Steel Electronic Bathroom...
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
How do i contact salter scale customer service i have a waranty issue with a scale
you can contact our customer service by this email address
sales@accurate-scales.com
Aug 04, 2009 | Salter Stainless Steel Electronic Bathroom...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Health & Beauty Logo
97 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
solver2010
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
