Question about Health & Beauty
How do i get my scale to weigh ounces - Health & Beauty
  • 1,830 Answers
What type of scale is this?
Posted on May 12, 2017
Salter high precision stainless scale 1078ss. How do i get it to weigh ounces
Put the weight on the scale. It should weigh ounces, pounds, grams, and killograms, all in the same unit.
May 12, 2017 | Salter Health & Beauty
How to measure 250gm dried herbs
If I needed to do that I would use a kitchen weighing scale and if the weight accuracy required was on the near-enough side I wouldn't care if the scales were old as I would weigh out 10 ounces.
If reasonable accuracy was required I would use a balance type kitchen scales with a 250gm weight.
If greater accuracy than that was needed I would ask at my local post office...
If still greater accuracy is needed you would first need a humidity controlled environment and about 24 hours for the herbs to stabilise before weighing...
Feb 24, 2017 | Health & Beauty
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
Cooler keeps freezing product
You killed the messenger! The refrigerant charge is probably the problem. The thermostat senses the coil temperature and not the cabinet temperature. If somebody put gas in it, the gas has to be removed, a vacuum drawn on the system and then the refrigerant charge weighed in by the ounce. It takes a critical charge and needs to be weighed in by an accurate scale that weighs in ounces. Hope this helps and good luck.
Jul 17, 2014 | Beverage-Air MT27 Beverage Cooler...
How do you recharge air conditioning on 2008 impala
There is a tag that is generally under the hood that will tell you the amount of R134a that is needed to charge the system properly. These are crittically charged systems and require a vacuum pump to remove non condensibles from the system and then charge the system with the amount of refrigerant EXACTLY required by chevy by the ounce which requires a scale. If you can find a scale that weighs in ounces and can start the count down at 30 pounds you have a good chance at sucess, or if you are using the local auto parts 14 ozs cans you might consider using your wife's diet food scale?
Jul 16, 2013 | Air Conditioning Condenser 2008 Chevrolet...
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
