Question about IBM Office Equipment & Supplies
HAVE A IBM 6400 PRINTER AND FORMS KEEP JAMMING ON RIGHT SIDE OF FEED
Inky
  • 691 Answers
SOURCE: Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Posted on Oct 14, 2007
SOURCE: printer
its waste cannon printer is very worst printer
i hav new one but it isnt work now
Posted on Mar 15, 2008
SOURCE: Printer will not feed paper correctly
I had the exact same problem and it was a foreign object (*** end lol). I fiddled about abit then turned the printer upside down, gae it a few taps and it was fine.
Posted on Aug 21, 2008
yooperbud
  • 8637 Answers
SOURCE: Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
  • 10 Answers
SOURCE: Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Posted on Mar 14, 2009
IBM 6400 Matrix Printer is printing twice over a previous line it seem on to happen once or twice per page of text there seems to be no issue with the tractor feed no drag on the paper source and the test...
Might be your gap is set to high. try moving the right lever from A to B for example and see if it clears it out. Also might be your parallelism, you will find to hex screws on the right and left of the platen assy that u can adjust. This will balance out the shuttle if one side is printing to light and another is printing to dark. Rory 708-597-4222
Oct 07, 2011 | IBM 6400 Matrix Printer
Need form feed configurations
contole code message come in the control penel
Oct 13, 2009 | IBM 6400 Matrix Printer
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
Need to change the printer ribbon on ibm 6400
BY WWW.IBM.COM/SERVICE
GO ON LINE AND TYPE THE FOLLOWING:
HOW TO CHANGE A PRINTER RIBBON IBM 6400
BEFORE YOU DO ALL THAT FIND THE RIBBON BOX AND SEE IF IT HAS ANY TYPE INSTRUCTION WHAT TO DO?????????
ROD
May 12, 2009 | IBM 6400 Matrix Printer
Keep receiving "End of Forms or Forms Jam on device XXXXXXX"
The problem was due to a block/clogged EOF(End of Forms) sensor. I resolved it by using a can of compressed air to clean/remove any foreign debris from the sensor.
Apr 08, 2009 | IBM 6400 Matrix Printer
Paper jamming
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 20, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Jan 06, 2009 | IBM 6400 Matrix Printer
Paper jamming
Oct 13, 2008 | HP Photosmart 2575 All-In-One InkJet...
Paper jam...
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Aug 18, 2008 | Lexmark X2350 All-In-One InkJet Printer
Paper jam
Feb 28, 2008 | IBM Lexmark Z715 InkJet Printer
23 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
