Question about Garden
Chain saw MS 250 has no spark - Garden
  • 398 Answers
SOURCE: Change Spark Plug on Eager ****** Chain Saw
yea you have to take it apart sorry
Posted on Feb 27, 2009
  • 1605 Answers
SOURCE: stihl chain saw
shut off the engine
pull out the hinged clip and loosen the wingnut
turn the adjusting wheel clockwise as far as stop. (on top of the adjustment wingnut).
tighten down the wingnut firmly by hand
fold down the hinger clip.
go to the following link, if you need the users manual.
Posted on Apr 09, 2009
  • 583 Answers
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Posted on Aug 04, 2009
  • 546 Answers
SOURCE: I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Posted on Sep 21, 2009
  • 6468 Answers
SOURCE: No spark on my homelite 150 automatic chain saw
remove the cover then the small wire from the coil crank it over if you get spark the wiring or switch is bad if still no spark the coil is bad
Posted on Aug 30, 2012
How do you remove the clutch on a 025?
remove spark plug.
block ther piston with a piston stop.
remove clutch drum exposing the clutch
it has to be turned clockwise to remove it. 19m socket
Sep 02, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Hard pull stihl ms 250
UH OH.......may be engine damage, from over heating or not enough oil in gas.
Dec 22, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do you change the clutch?
Remove the side casing. (bar side)
Take off bar and chain.
Remove E-clip holding the clutch drum on.
Remove clutch drum and needle cage bearing.
This should expose the clutch.
Remove spark plug.
Use a piston stop to stop the piston rising, Sometimes a knotted piece of pull cord fed into the cylinder is just as good.
Turn the clutch clockwise with a socket to unscrew.
To put clutch back on turn anticlockwise till piston cycles back and hits the piston stop again and tighten. Replace spark plug and clutch drum, bearing, bar and chain and side casing.
Mar 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl 025 starts but cuts out have replaced spark plug and new carb
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
Oct 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Ms 170 leaks bar chain oil out bottom, no oil on chain
Your clutch drum bearing has gone bad, letting the clutch drum to move around and cut into the oiler behind it, so now it just pumps the oil out that hole. You have to get that fixed to use the saw, otherwise you're going to cause catastrophic damage to the saw very soon.
Sep 25, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
