Question about Energizer Computers & Internet
When was an energizer 2032 battery with a date code of KA
It says date and time not set after that it shutsdown
If you keep losing your date and time it is most likely that you need to replace the CMOS battery. You can usually access it from under the panels that are removable Memory, Hard Drive etc. It is a watch battery size 2032. Once replaced reset your time and date and time zone and you should all good good luck
Mar 25, 2015 | HP Compaq nc6400 Notebook
What is the difference between a cr2035 and a ecr2035 battery
The E is probably Energizer's reference to itself.
See the correspondence in screen capture.
Jan 05, 2014 | Energizer Ecr 2032 - Battery Cr2032 Li 225...
Every time I power on my laptop, the date and time is set to years ago. I've changed it to the correct date and time a lot, turn it off when I'm done, but it goes back once I turn it back on. I have a...
You need to change the internal clock battery. It's referred as a CMOS battery or a system battery. It will most likely be a silver button cell...either a 2016 or 2032. You will most likely find it by removing the main battery and one of the bottom access covers. After you change it, boot up to Windows and change the time and date. It should now retain the settings.
Nov 05, 2013 | Gateway Computers & Internet
Can I change the battery in the FOB myself or do I need to take it to a dealer?
You can change the battery yourself. All you need to do is follow this link
http://youtu.be/ElNjcWKlx-A
You will need one Energizer 2032 lithium 3V battery.
Dec 02, 2010 | 2004 Porsche Cayenne
When i boot my system iam getting an error Check Date and Time settings and System CMOS Checksum Bad and Default configuration is used. F1 : Resume F2 :- Setup
Hi Good day!! That error maybe cause of your CMOS battery it may be not working, replace your CMOS Battery (2032 3volts), after you replace it with new one, set your date and time setting according in your time zone.
Oct 13, 2010 | Computers & Internet
What is the battery number
Generic #cr2025 - Energizer #2032 Its a 3.0v battery
Oct 04, 2009 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
I just wanted to know what the flat watch battery is for in the kid tough digital camera?
It uses a CR-2032 lithium button cell battery.
It's a 3 volt battery made by a variety of generic and name brand manufactures including Energizer and Duracell. You should have too much trouble finding one as they are fairly popular in electronic devices.
Mar 03, 2009 | Fisher-Price Kid Tough Digital Camera
We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Feb 23, 2009 | Taylor & Digital Scale Lithium Scale
Time and date
The cmos battery is probably dead. It'll need to be replaced. Generally, it's a 2032 battery (button cell about the size of a quarter).
Dec 04, 2008 | Computers & Internet
BIOS setup won't allow me to set the system time and date for Asus m2n-sli deluxe motherboard.
dear friend
u try system date with windows time and date and then trun off yr pc and put off yr power cable for 10 20 sec then plug on power then try if system date still not work then changer for Mother boad BETTRY it's 2032 number bettry try this one
thanks for using fixya
jo_chinmay
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Energizer Computers & Internet Experts
Tom Chichester
Michel Laprise Sr
Are you an Energizer Computer and Internet Expert? Answer questions, earn points and help others
