Question about Ematic Audio Players & Recorders
My ematic wont turn on it stays blackbscreen i found my bobbypin on the magnet part
My ematic 7 inch quad-core tablet wont turn on or charge
Either your charger is fubar or your batteries can no longer take a charge.
Oct 12, 2016 | Ematic 7" Touch Screen Tablet
My ematic wont turn on unless it is charging. And when i take it off, it makes a sound and turns off
Hi. I beleive you should replace the battery. Because it no longer holds a charge. Replace it. Good luck.
Jun 15, 2011 | Beond Ematic EM304CAMB Digital Media...
My ematic e6 froze at the first screen and wont change.
yea it does that to me too but u should just leave it alone let it die on its own theres nothin u can do. but can u help me with a question my ematic e6 wont let me open to my music file no more and i dnt know y can u help me?
Mar 02, 2010 | Audio Players & Recorders
Computer not reading drive for Ematic mp3 player
i am having that same problem, and ontop of that my ematic is frozen! when i turn it on the picture of the river comes up and stays up untill you turn it off. i have the ematic 5 series, is thier a solution?
Dec 31, 2008 | Samsung YP-K3 MP3 Player
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Dec 27, 2007 | Kitchen Appliances - Others
Ddo error code
ok, I got mine to work. Push the button down on the back side of the soap dispenser that says push down or push here (to take the tray out). When you have it out you will want to turn it over and there are 3 or 4 white tabs. You will want to pop the front part of the drawer off and then on the bottom about an inch in/down there is a small slot to put it into. It is the same size as the magnet and the magnet goes with the squares on the top and bottom. You cannot actually see the magnet when the drawer is put back together. When I talked to the service man he said they did away with the magnet on the new model. How stupid to put it there to begin with!! Hope that helps and if it doesn't ask again.
Apr 14, 2007 | Frigidaire GLTF2940ES Front Load Washer
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
