Question about Proscan Televison & Video
I have a Proscan 39" LEDTV, model PLDED3996A-C2. The screen went black.I had a friend say she has to replace the "light" on her TV. Does this TV have a light?
  • 375 Answers
SOURCE: proscan tv
enter the user menu to see if you have text or telecaption on,if not your vertical section is possible at fault if the bottom half of the screen is blacked out.
Posted on Mar 20, 2008
  • 10 Answers
SOURCE: when i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Posted on Jul 23, 2009
  • 556 Answers
SOURCE: I have a new proscan tv which we installed about
It's still in warranty call whomever you bought it from to have it repaired
Posted on Aug 11, 2009
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
  • 259 Answers
SOURCE: APEX tv model #AT1302 My tv screen is black with a
child lock is active. Unlock press function and then mute on remote. only way to do it.
Posted on Jan 08, 2010
I need the codes for the 'Dish Network remote' for my ProScan PLDED3996A tv.
The codes are for the TV not the remote, it only stores them, the code is the same no matter the type of remote. The Proscan TV code is listed as 0047
Dec 15, 2016 | Proscan Televison & Video
Model PLDED3996A. Why doesn't Verizon remote control work?
Codes are stored in the remote. Your Verizon remote may not have a code for your Proscan TV.
Nov 29, 2015 | Proscan Televison & Video
Plugged in my proscan ledtv model # pled1960a-g the unit turned on displayed proscan then picture went to yellow,red,green,black,and white, only way to turn off is to unplug it
This is somewhat bad symptom indeed. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 17, 2015 | Proscan Televison & Video
Proscan led 39" tv no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions
May 21, 2015 | Proscan Televison & Video
Proscan codes
0270.0277,0274. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 02, 2014 | Televison & Video
Proscan tv troubleshooting
How do you hook up a computor to my plded3996a-c
Jan 07, 2014 | Televison & Video
My proscan 32lc30s57 not turn on
Purchase 32 inc Proscan on black friday, 7 months later, tv would not turn on, the light comes on, but screen is all black, what should I do
Feb 27, 2013 | Proscan 32LA30Q Television
Proscan 47LB45H tv turns on , has sound , no video
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 19, 2017 | Proscan 47LB45H 47 in. LCD TV
Televison & Video Logo
42 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
