The button of my Beko DCUR801W has broke how do i fix it, not the on and of one the one that turns the tumbler on next to the alarm button
2 Suggested Answers
SOURCE: Replaced the ignition lock and tumbler. Alarm going off nostart
i have lost the keys to a 99 ford exploxer
Posted on May 31, 2009
2007 volvo v50 key stuck in ignition vehicle totally shut down
It is best to call a locksmith, unless you know how to take apart the ignition tumbler and put the assemly locks in the correct order. It sounds like the key tumbler hold in broke and all the tumblers are loose and causing the key to be stuck. If you want to hurry the job for the locksmith and save money, buy the key tumbler assembly for your vehicle for the locksmith to install. Otherwise he will have to make the trip to buy the assembly, which in turn costs you more money. Mechanic shops can replace key tumblers too but when it is stuck in the column, it takes a lot of effort to remove if they are unskilled.
Jun 06, 2016 | 2007 Volvo V50
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
Beko quick wash button broke
call service center to provide the spare part !! it's all to do and nothing to be disappointed
be happy
Oct 18, 2014 | Beko Washing Machines
2000 VW cabio door locks stopped working
chances are you broke the 10cent pot metal piece ($30 at dealer) that attachs to the tumbler behind the scene where the key inserts and engages the locks. The good news if your handy you can fix this. The bad news is probably it will break again (from personal experience). To fix it --- simply disengage the alarm with your fob --- remove door panel (need a star wrench to remove the parts holding the panel) -carefully pry the outer panel of the frame --- peel back the plastic to acess the cavity of the door - - locate the broke piece and replace (make sure you keep track of the sequence, meaning take a picture of the unit befoe you start and as you dismantle it) hopefully this helps!
Dec 07, 2012 | 2000 Volkswagen Cabrio
Alarm problem cabrio 2001
You can take the door handle off the drivers side and replace the tumblers in the key slot or just remove the tumbler pieces and then any key will turn in the lock. What really matters is that you have to center the door latch lock piece with a lock or a flat screw driver.the line up should be straight up and down in side the door you can see it when you get the door handle off.
Nov 26, 2017 | 2001 Volkswagen Cabrio
you need to have the keys programmed with a ford scantool. that's the only way.
May 24, 2009 | 1997 Ford Explorer AWD
1997 Buick LaSabre, the alarm keeps going off without any provocation. Also went off as I was putting things into the trunk. Stopped when I opened the door with a key.
might be ignition tumbler , my friend had same problem , the key sensor broke , there is reset process after new tumbler is installed
Feb 19, 2009 | Mercedes-Benz C-Class Cars & Trucks
I have lost my instructions to unlock this TARGUS PA400C DEFCON 1 AUDIBLE NOTEBOOK ALARM (PA400C) Do you know where I can find what the default code is?
this may help
Due to the nature of security devices, there is no "magic unlock" code for the Defcon device. To recover a lost combination:
·Set the tumblers to the last known combination.
·While applying pressure to the red release button, rotate the tumblers up one digit and then down one digit on each of the individual tumblers.
·For Example: If your last know combination was 565
1.Set the tumblers to 565
2.Hold the red release button in and rotate the 1st tumbler to 6 so that the combination is now set to 665 (If this is the set combination the red release button will move in)
3.Hold the red release button in and rotate the 1st tumbler to 4 so that the combination is now set to 465
4.If not found move onto the 2nd tumbler and repeat step 1-3
5.If not found move onto the 3rd tumbler and repeat step 1-3
Dec 30, 2008 | Bennett Marine GARMIN StreetPilot...
Washing Machines Logo
Top Washing Machines Experts
