Question about The Watches
My watch only works when it is worn on wrist when it is off the wrist it stops i think the temperature of the body keeps it going and it is battery powered
    New Friend:
  • 4 Answers
Most likely the battery has a loose connection and possibly the back cover isn't on tight enough, and you wearing it is applying the right amount of squeeze to make the battery connection.
On some watches there is a little metal clip holding the battery in place with a screw under pressure. When you remove the screw to change the battery, if you aren't careful the pieces can go flying. Some shady places will just say eff it and put the new battery without the pieces they lost. Then the battery can move around and manifest itself with strange problems such as yours. I know of kinetic watches, and solar watches, but as far as I know there are no biothermal watches. Yet.
Posted on May 13, 2017
    Master:
  • The Master
  • 923 Answers
Is it all digital (with a digital readout), or does it have two, or even three hands that point to the time?
Posted on May 12, 2017
I have 2 movt wrist watches work good when left off wrist but when worn will stop working after worn 6to8hours WHY
Check the two connections where the battery makes contact, most likely one of the screws is loose or missing, or may have some corrosion from a battery leak..
Feb 19, 2015 | Watches
New watch bulova 96R-19 women, and dont know how to start...
I have read the instruction for this watch and I am surprised how little they tell you!
The description of the watch does not say if it is automatic or battery driven so I shall give you two alternatives to try:-
1) If it is battery driven, then there may be a wedge under the winder to prevent it going into the running position (to save the battery while it is on the shelf). Pull this out and push the winder home.
2) If it is automatic, then it is mechanically driven by a spring and needs to be wound up. This is done by either turning the winding knob or gently shaking it from side to side form some minutes. Once going, such a watch needs to be worn daily to keep it running. They will normally run for 1 - 2 days before stopping when not being worn.
If you were not given instructions with your watch, you can get them from their web site http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=96R19&brand=bulova.
Dec 22, 2010 | Bulova 96R19 Wrist Watch
Watch only works when not worn
You may not believe me - but I think it is You.
There are some people who stop watches from working - and affect electrical items.
These people are called SLIders - because of the original research on "Street Light Interference"
Be very careful around electrical items when you are stressed - or you could blow lightbulbs.
- Or it could be temperature this watch is responding to. If it stops when left somewhere warm - it's temperature related.
Feb 07, 2010 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
My GN-4-S watch doesn't keep time when not worn , in daylight hours and in the sun it keeps perfect time when worn.
Visit your local Citizen dealer and for new capacitor. It looks like your old capacitor can not accumulate enough power to keep watch going in darkness.
Rate me, please.
Jan 23, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
New radaiter fitted temp still going into red what could the problem be
Its not the fault of radiator. Its just the thermostate body attached to the engine on battery side. It is underneath the Vacuum pump and has temperature sensor attached to it. If the body inside is corroded then it shows other temps rather than actual. Check it, may be it'll solve your problem.
Jan 20, 2010 | Peugeot 307BR Wrist Watch
I have a 1968 swiss made snoopy watch. How do I wind it, it has no battery.
is this watch automatic?? if it is it will have a small weighted roller inside, if you wear the watch and twist your hand (as if using a screwdriver) it should work, these watches have to be worn all the time and rely on everyday wrist movements to keep going. good luck
Aug 11, 2009 | Watches
I just recently purchased a brand new Casio G-Shock GW-002KA 2913
if there is a black screen and shows chg thats mean your battery level is to low ////// so you must charge as soon a possible,,,,,,
Jan 21, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Looses time when worn. but keeps time when not on wrist
this could be the electrical in your body. try it on the other arm seriously dont know why but try it and let me know. joe
Dec 02, 2008 | Bulova Watch
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Watches Logo
24 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
