Question about Keurig Coffee Makers & Espresso Machines
What would cause a k-155 keurig to not refill and shut down.
Sled gets to 155 deg and shuts down
Change the thermostat,is the water circulating?
Feb 23, 2014 | Polaris 2006 SwitchBack FST
Keurig b70 water tank leaks out all over the counter
Shut-off valve failed, retry a second time and it will reset accordingly.
Dec 31, 2012 | Keurig Platinum B70 Coffee Maker
My Keurig will not produce any coffee. It is as though the water system is shut down
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Aug 29, 2011 | Keurig B50 Coffee Maker
Our Keurig overheated and it melted the k-cup inside of it. Now it won't shut off without unplugging it.
The thermostat causes that problem it is already shorted hence it connected permanently the current causing a won't shut off without unplugging. Have it replace and it will go back to normal.
That's the solution to your problem friend
Mar 31, 2011 | Keurig B60 Coffee Maker
Our keurig is refilling only when it is brewing coffee..and when it does refill, it only puts out 3 oz of water at a time
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
Jan 06, 2011 | Keurig B50 Coffee Maker
Water pumps out half way and then brewer shuts off
The new silent models of the Keurig machines have a fine screen in the base. The check valve in the removable resevoir seats into this screen and the flat post in the center of the hole is part of it. My machine would shut down when refilling after brewing a cup and there was never the same amount in the cup twice in a row. I found this screen totally plugged up even though I was using the in-tank fliter. The screen can be removed from the bottom and cleaned if you are mechaniclly inlined or you might try a Q-tip from the top, of course un-plug it before you try either.
Aug 17, 2010 | Keurig B50 Coffee Maker
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Keurig makes loud noise and sounds as it refills
hIi would return this should be under warranty
Jan 22, 2010 | Microwave Ovens
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
