Program list empty - Computers & Internet
How do I delete Linkedin from laptop
Well depending on windows version go to programs and features in win 8 win XP -7 add and remove programs. It should show on the list of installed programs. Just select and click uninstall..... If it is not on the list then you are going to have to search for it on you hard drive (usually c:drive) Once you find it see if it contains an uninstall program. If it does not do not attempt deleting it since could cause pc errors. I suggest the using a program such as REVO UNINSTALLER.
Even though the program list in Revo may not show it you can use the hunt feature. Locate the program folder Open Revo put it in hunt mode and drag and drop the program to Revo. Follow instructions and you should be golden. to double check that it has been removed shut down pc/laptop wait 10sec then reboot and check for the program you wanted gone. I hope this helps with a few options should one not work. Note you may find an emty folder left behind with the name of the program you can just simply delete it. Open first to make sure it's empty.
Sep 24, 2014 | Dell Computers & Internet
Machine stopped on the rinse cycle with the display showing "caution high water level", I tried to cancel the program and the display shows "cancelling program" and sound like it's proceeding but it...
Unplug your machine and start a new load. The machine will since that there is enough water in the machine and finish the cycle. If you are still having problems, call the manufacture's phone number listed in your user guide or their web site. They usually have contact information listed. Also, check the troubleshooting guide in your user's manual. You can probably download one from the internet.
Dec 10, 2013 | Dyson Washing Machines
I cannot install my new security soft ware untill I delete the current one that is running. When I go to the add/remove program it will not open and let me remove the previous installed program. The...
You do not list the program you are trying to uninstall. If it is Norton or McAfee ignore the rest of this post and list the program you are wanting to remove. If not then you must first stop your old program from running before attempting to uninstall it. You can do this in Task Manager. Right click an empty space in your task bar at the bottom of the screen. Click Task Manager. Look in the processes tab and locate the program you are referring to. Then click Stop Process and proceed to remove it. If that does not work click Start >> Run and type in msconfig then hit run. Find the program in the Startup tab. Disable the program from running at Startup. Now Restart your computer then uninstall the program.
Jun 14, 2010 | Webroot Internet Essentials (83210)
How to enable internet on Dell Precision M4400
fistly confir that which antivirus u use.
if it norten, thn follow these step.
Scan for Internet-Enabled Programs and Apply Firewall Rules Using the Interface
  1. Double-click the icon in the system tray to display the Norton Internet Security window.
  2. Click to select Status & Settings and double-click Personal Firewall to display the Program Control screen.
  3. Click the Program Control tab:
    • If the Manual Program Control list is empty, click Program Scan to look for programs that use the Internet.
    • If the Manual Program Control list is not empty, click all the check boxes and press Delete and then OK.
  4. Click the Program Scan tab to display the Program Scan window.
  5. Click to check the scan boxes under choose the drivers you want to scan.
  6. Click Next to allow the Program Scan to list all the Internet-enabled programs found on your computer.
  7. Click All to select all or check the box next to each program name to select the programs that you want to create firewall rules for and click Finish.
new_note.jpg Note: All the programs that you select appear in the Program Control dialog box. In almost all cases, you do not need to modify the Internet Access or Category options. If you do need to modify these options, click the triangle to the left of the option in the Internet Access column and select the change.
  1. Click OK to return to the Norton Internet Security main window.
  2. Re-enable Norton Internet Security and launch the program that is having difficulties accessing the Internet.
  3. If the application now works with your Internet connection, you have successfully created firewall rules for the programs you selected.
    If the application is still not working with your Internet connection, proceed to Check if a rule in Norton Internet Security or Norton Personal Firewall is Blocking Internet Access
Nov 17, 2009 | Dell Precision M4400 Notebook
Scan to list box is empty in the HP Solution Center software which is required for "Where do you want to send the scanned image". I get a error message asking for a destination but as I said the box is...
If there are updates, they'll be available on www.hp.com. Click the support link and then either enter your model number or drill down the products list to find your product.
In dealing with HP's all-in-ones, software called the HP Director is what I used to define what goes in the send to list box. Also, many of the newer all-in-ones, you can also program these options through the printer's console controls (those with a status or picture window).
Oct 04, 2009 | Office Equipment & Supplies
Printer driver doesn't install
Have you scan to see if you have a bug hideing in your system. Programs dont leave by there self. Use a program to scan your reg files. and system 32 files. Good luck
May 26, 2009 | HP LaserJet 2200 Printer
Refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
May 16, 2009 | Lexmark X3650 Printer
Videos list showing empty
You need to use the supplied Sansa Media Converter program to convert videos to a format the Sansa can handle. If you don't have the SMC, you may download it here.
May 13, 2009 | SanDisk Sansa e260 MP3 Player
Computers & Internet Logo
David Payne
David Payne
