Question about Garden
Where can i get parts for a 2001 arctic cat 4004x4
Fuel tank,rebuild kit for carb
    Top Expert:
  • Garden Master
  • 12,744 Answers
Look online--most sport/rec shops --motorcycle shops-off-road supplies
Posted on May 12, 2017
My arctic cat 4X4 with a Mikuni BST 31 carb suddenly lost power and fouled the plug.New plug makes it start instantly and it runs great for 10 sec then fouls plug.Diaphram is good. Bowl not leaking
Pull the carb off and rebuild it, it either has a failed fuel inlet valve or a sticking float or a plugged jet from dirt in the fuel. If you are careful you can do this clean out with no new gaskets, use carb spray and compressed air. You may need a new fuel inlet "Needle Valve and seat". If you do find allot of contaminates in the float bowl you will need to clean the fuel tank and lines to the carb.
Apr 03, 2017 | ATVs
I bought a 73 arctic cat jag 3000, was running great, now it doesn't want to stay running for more than a minute. It looks to me like its not getting enough fuel through the fuel pump to the carbs
You may have a clogged filter sock in the fuel tank pickup, pull the fuel tank and make sure there isn't gunk or dirt in it. If there is you will need to rebuild the carbs.
Jan 07, 2017 | ATVs
I have a 2005 Arctic Cat 500 that will crank and run great. Push the throttle acts starving for gas. I have replaced the fuel filter, fuel line, and cleaned the tank. Also replaced carb. NEED HELP!
Try running it with the cap off the tank. Sometimes the cap will fail and wont allow air back into the tank when you draw fuel from it. This starves the engine of fuel.
May 20, 2016 | Arctic Cat 2006 500 4x4
My 98 arctic cat 500 has fuel and spark and wont run
rebuild the carb, include a new float and throttle spring and replace any dog eared screws. The kit comes with a new needle valve and two jets and all the gaskets. Take you time and replace all the parts. Be careful to put the keeper clip (ring) on the proper groove on the needle valve and extra care when bending the float arm to proper travel specs... they will break off if you are rough. Write down the mixture settings and use those as your starting point to readjust the mixture. The engine is designed to use choke when starting and should have a slight skip when idling that smooths out when adding throttle.
Feb 27, 2015 | ATVs
2012 arctic cat idles fine but cuts out when given throttle... any ideas?
are the fuel lines clear? also check the float in the carbureter. if it has a hole it will sink causing fuel starvation
Nov 30, 2014 | Arctic Cat 2013 Prowler 700 HDX
Arctic cat 400
Sounds like the carb is gummed up
here is a link to all the Arctic cat ATV service manuals
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
May 04, 2014 | ATVs
Arctic cat atv problems
yes as well as the carbs are still dirty
Dec 29, 2013 | ATVs
How to fix a leak fuel from the carbuator or primer for a atv arctic cat 500 2005
Oct 27, 2013 | ATVs
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
