Question about The Office Equipment & Supplies
SOURCE: Stainless Steel Cover for Grill
Yes the parts are available .As for the removing the material left on the cover,I would use a very light 400 sandpaper first to see if that makes progress.Without seeing the cover it's not advised to give any advice, only because without the right pressure and tool used it will vary on how this will be removed.
Posted on Jun 24, 2008
SOURCE: Brevill Grill Removable plates - dishwasher safe?
Greetings jackneve,
The manufacturers specifications would indicate these plates are indeed dishwasher safe!
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 25, 2008
SOURCE: PAPER FEED MECHANISM IS CONTAMINATED
what you could try to do is get a sheet of paper, have it pass through the printer and using a semi-wet sponge to wipe the dirty roller as it rolls out the paper. You can repeat this process as many times as necessary, until you clean up the roller.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Posted on Jan 19, 2011
Testimonial: "Thanks for the response. Would still like to know how to dismantle document table."
SOURCE: damp paper plates left white
Hi Jim,
Sorry to hear that.
The water has turned the finish opaque. The remedy depends on the type of finish on the table. If you have some woodworking experience .........
1. I would first try buffing the spot with 0000 steel wool, then rubbing it lightly with mineral spirits. Do not substitute anything else.
2. If this does not work, you can sand the spot with wet (soaked overnight) "wet/dry" sandpaper about 1500 to 2000 grit. You can get this at an auto shop. Then fill the spot with polyurethane finish. After the polyurethane dries for 24 hrs, sand with the above sandpaper, then finish with steel wool.
Good luck. If the area is larger, like the paper plate, then I would contact a furniture refinisher. I might consider contacting someone before attempting a repair either way. Cherry tables are premium!
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie, "woodworker by night"
Posted on May 22, 2011
May 08, 2016 | Saws
Jan 29, 2015 | Weber Grilling
Jul 14, 2014 | Vacuums
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
Oct 11, 2010 | Russell Hobbs Stylish Glass 10810 Indoor...
Apr 08, 2010 | Coleman Roadtrip Grill LXE 9949-750
Jun 24, 2008 | Thermador PCS484GGUS Gas Cooktop
Jan 21, 2007 | George Foreman G5 Indoor Grill
Apr 20, 2018 | The Office Equipment & Supplies
26 people viewed this question
