Question about Samsung SyncMaster 245BW Monitor
Yellow and blue lines on 245BW
I have yellow and blue horizontal static lines across my screen. It doesn't happen when I first turn it on but when I open some windows. Especially anything with a photo on it. I've had the problem where the monitor will flash off and on as well. I'm using a Mac Pro desktop. That shouldn't matter. I took it back to the place where I purchased it and it worked fine when they plugged it in. I told them it didn't happen right away and never consistently. I have it set on the default resolution which I believe is the highest available. Any ideas?
  • 2 more comments
  • Anonymous Nov 27, 2007
    I have the exact same problem. I thought maybe it was the dvi cable supplied with the monitor so i switched it with my old one and problem remains. Seems to be upredictable.
  • dshow Dec 13, 2007
    I have the same problem. I have 2 of these montiors and one is doing it 6 times out of 10. The funny thing, it only happens from a cold boot up, not when it's been running a while. I changed DVI cables, no dice; and now changing the graphics card to see if that fixes it. I think it's the monitor. But an easy way to temporarly solve the problem is if you turn the monitor off then on again. This seems to bring back the image to normal. It won't happen again until I leave the PC off for a night then turn it on the next morning. They come back but not through the bios. Only once I get into the OS. Any suggestions? I'm going to call Samsung.
  • Anonymous Jan 07, 2008
    I have horizontal streaking intermittently!
  • Lonewulf13 Apr 18, 2008
    Yep...same problem with my 245BW...the yellow an' blue lines thing. :( So, has anyone got their replacement monitor back from Samsung? Plz advise.
Well, my monitor is going back to samsung for a replacement unit. I plugged in my monitor in a bunch of other PCs and it's doing the same thing regarless of the PC or graphics card I use. Now I know it's the monitor. Getting it RMA'd with Samsung. Only had it for 18 days. Hope they send me a new one and not a refurb.
Posted on Dec 15, 2007
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
I'm having problems with the Samsung 245BW. I bought the first one at Sam's Club and it developed some pixelation problems, i.e. blue and yellow horrizontal lines across the screen. I returned it to...
you can try this ,
check the monitor on the different wall outlet/ socket or check with different computer wheather it gives the same issue .. third option is check with both DVI and VGA ports differnetly.. please check wheather you are getting lines on the bios screen when u start the system because if you r getting lines on the BIOS screen (f1) then there is a issue with the monitor else issue with the video card ................try this ,if possible revert for the same issue
May 21, 2008 | Computers & Internet
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Samsung SyncMaster 245BW Monitor Logo
152 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
