Question about Vehicle Parts & Accessories
How do I charge my Superex Jumpstart portable power system?
  • 4,184 Answers
Most of the jumpstarter and portable power packs using a sealed lead acid battery can be charged from the car cigar lighter with the lead usually supplied or with the mains power charging adaptor, also usually supplied.
Most such units are similar in design and function but slight variations between different manufacture mean it is wise to consult the instruction manual before proceeding, though such differences aren't challenging to folk who are familiar with them.
One word of caution - such units can give reliable service for years if they are kept fully charged and used considerately, but leave it discharged or semi-discharged and it can be ruined in a month or short circuit the battery leads or connect it wrongly and it can be ruined in a second.
The rule is recharge after every use and if not used then check the state and recharge if necessary every month or two.
Posted on May 12, 2017
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I'm lost I have a superex slim power bank 2600xmAH I try charging and the percentage of power remaining goes down, I'm not doing it right. There is in & out at one end for connections, what!!!
in is for recharging the power bank and please note that it takes time to charge. and out is for your charging your devices when the bank is charged. yes you can use the same cable for both by inverting. and do not loop i.e connect the in to out whatever you do
Feb 17, 2016 | Computers & Internet
How to recharge superex jumpstart/compressor
Plug in the cord with the switch off. If the battery is still good in the unit then it will take a full day to charge. If you charge it for a full day and you still have nothing the battery is bad. If this is a new unit, check to see if it is under warranty.
Sep 06, 2014 | Superex Canada Ltd Emergency Jumpstart...
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Jun 28, 2014 | Power Center Jumpstart 11-411
How do i charge it
On the back there should be a cover over a plug. Lift the cover and plug it in with a single outlet extension cord.
Jun 27, 2014 | Superex Deluxe power station with air...
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
May 23, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
