Question about Maytag Refrigerators
I have a Maytag H20 refrid MF12568AES. The ice maker erratic;cleaned coils, replaced inlet valve and same results.The amount of ice is about half of the norm when it does work. What do you suggest?
  • 183 Answers
SOURCE: kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Posted on Aug 23, 2007
dididsaythat
  • 291 Answers
SOURCE: ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Posted on Sep 03, 2007
  • 1122 Answers
SOURCE: Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Posted on Sep 22, 2008
philbran
  • 242 Answers
SOURCE: Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Posted on Jun 11, 2009
SOURCE: Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
Posted on Jan 11, 2010
Ice maker will not fill .pour water in manually and eventually it may or may not dispense.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
May 12, 2015 | Kenmore Refrigerators
I have a Maytag French door refrigerator and the ice maker has stopped working. We changed the water filter right before it stopped so I'm thinking there may be a vapour lock. But that's just a guess,...
ICE MAKER not making ice:
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Mar 26, 2015 | Maytag Refrigerators
Water not coming out
WATER INLET VALVE:
Mar 23, 2015 | Samsung Refrigerators
Only making two to three cubes at a time!!
i WOULD TEST THE WATER VALVE AND THE COILS FOR OHMS AND FOR FULL VOLTAGE
WATER INLET VALVE:
Feb 26, 2015 | Refrigerators
Maytag ice maker 1c11b not making ice replaced the inlet value ice maker is making noise but no ice
WATER INLET VALVE:
Jan 05, 2015 | Maytag Refrigerators
Clicking noise in freezer I am assuming to try to make ice, no ice being made?
Hi and welcome to FixYa, I am Kelly
Ice makers can stop ice production due to poor air flow though the evaporator coils or through the failure of the ice maker module. If your certain the clicking noise your hearing is from the ice maker itself here is are some steps that you can use to troubleshoot the ice maker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
This step from the above link is important:
TEST PROCEDURESIce Maker Plugged In To PowerShut-Off Arm Down-Freezer Cold
Test points L & N will verify 120 volts to Ice Maker module.(Make sure your test probes go into the test points 1/2".)
Test points T & H will verify if the bimetal thermostat is open or closed.
Short T & H with an insulated piece of wire ( 14 gauge) to run the motor. If the motor doesn't run, replace the module assembly. If you leave the jumper in for a half of a revolution, you can feel the heater in the mold heat up..if it's good.
Remove the jumper and the water valve will be energized in the last half of the revolution.
Once you insert the jumper between T & H touch the bottom of the ice maker and check for any signs of heat within the first minute. No heat = bad mold heater. It can 3 - 4 minutes for the sweep arm to harvest the ice.
Stick your finger back in the ice maker fill tube area in the plastic rectangular funnel area and check for ice build up. If the funnel is blocked with ice also pinch the ice maker fill tube for an ice block.
Should you notice ice in the funnel and the fill tube most likely the inlet water valve is bypassing water into the ice maker causing an over fill and ice build up condition. The remedy here is to replace the inlet water valve. They are NOT repairable. (Most of the time if the inlet water valve is bad your ice cubes will be fused into an ice block in the ice bin.) Also... if the ice maker fill tube is frozen full of ice... it can take up to 30 minutes using a hair drier to melt the ice as the insulation in the back of the freezer compartment keeps the ice maker fill tube from warming up enough to melt the ice in a timely fashion.
If you discover that the ice maker has over filled you can use a hand held hair drier and melt the ice in the ice maker.
If the ice maker seems to work fine then the freezer may be above 18 deg F. This is usually caused by ice build up on the evaporator coils as a result of either a defrost circuit problem or a slow running evaporator fan.
Thanks for choosing FixYa,
Kelly
Feb 20, 2011 | Maytag MBF2258HE Bottom Freezer...
Ice maker has stopped working. I have made sure that the ice detector arm is down.
Hi and welcome to FixYa. I am Kelly.
When and ice-maker stops working there can be a few reasons why this happens.
1. Often there is a problem with the automatic defrosting circuit and ice starts collection in larger than normal amounts of the evaporator coils resulting in restricted airflow in the freezer compartment. This in turn results in the freezer compartment warming above 15 deg F and the ice maker thermostat requires 16 deg F or below to activate the ice making cycle. Once the temp is above 16 deg F the ice maker ceases to function.
2. There can be a problem with the ice maker water valve. The coil can fail. The plunger can get stuck or there is debris in the water supply.
a. Turn off the water supply to the unit and disconnect the water line. Be careful when you remove the line. The water valves in use today use a star clip inside the water valve to retain / mate the water line to the water inlet valve. The clip can be damaged if your not careful. Then check for water flow by briefly turning on the water supply. It should almost fill a glass of water in around 7 seconds. Reconnect the water line after testing.
After doing the above if you have not determined the cause use this link to assist in your troubleshooting:
The link will show you how to cycle and trouble shoot the ice maker and or water valve. I recommend you read it thoroughly before starting.
Thanks for choosing FixYa.
Kelly
Oct 19, 2010 | Maytag MBB2256G Bottom Freezer...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
I have Maytag MTF1954ARA with ice maker which stopped working. Water is available, filter OK, Water inlet valve removed and tested OK. Is there something else to check before I have to remove/replace ice...
Pour about 3/4 cup of water into the icemaker . If it dumps the icecubes but doesn't refill with water , then replace the water inlet valve . If it doesn't dump the cubes , replace the icemaker . Make sure the coils are clean down by the compressor also .
Aug 02, 2009 | Maytag Refrigerators
Refrigerators Logo
43 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
