Question about The Computers & Internet
How do i update my software if the current network is busy
How can I turn off the busy signal on my phone?
Check your iPhone settings
  1. Turn airplane mode on and off. Tap Settings > Enable Airplane Mode, wait five seconds, then turn airplane mode off.
  2. Check your Do Not Disturb settings. Tap Settings > Do Not Disturb.
  3. Check for any blocked phone numbers. Tap Settings > Phone > Blocked.
  4. See if Call Forwarding is turned on. Tap Settings > Phone > Call Forwarding.
Update your software
  1. Check for a carrier settings update.
  2. Check for an iOS software update. Some updates might require a Wi-Fi connection.
Remove and reinsert your SIM card If your iPhone has a SIM card, remove the SIM card, then reinsert it. Update your Preferred Roaming List (PRL) The PRL determines the cellular towers that your iPhone uses for cell service and selects those with the best signal strength.
  • If you're on the Verizon network, dial *228 and select option 2.
  • If you're on the Sprint network, dial ##873283#.
Contact your carrier When you contact your carrier, check the following:
  • Your account is set up to use your iPhone.
  • There aren't any localized service outages.
  • Your account doesn't have a billing-related block.
  • Your calls don't have errors on the carrier system.
Check your network settings
  1. Reset your network settings. Tap Settings > General > Reset > Reset Network Settings. This will erase all current saved settings, including Wi-Fi passwords, preferred networks, and VPN settings.
  2. Try to make or receive calls in another location.
  3. Switch to a different network band. Tap Settings > Cellular and turn off Enable LTE, 4G, or 3G (this option will depend on your carrier and device model).
Still can't make or receive calls? If you still can't make or receive calls, restore your iPhone as new.If restoring doesn't fix the issue, contact Apple Support or take your iPhone to an Apple Retail Store or Authorized Service Provider.
Mar 14, 2016 | Panasonic Lands Phones
Nokia e63 country code
To get Country code(Network Unlock code) You need to specify the current network it is locked,country ..Visit the site
Theunlockspot.com/nokia/rs10wp8/ get Country code for NOKIA E63 and unlock it.
Nov 02, 2012 | Handmark Software MobileLists (950142) for...
My toshiba satelite won't connect to the internet and i get an error message saying its my network adaptors. does this mean its a software problem or will i have to physically remove and replace the...
Hello.
Test your laptop at a different location to see if any difference.
If still the network adapter, first try to update the driver by going to Device Manager, find the network adapter and select update. You'll actually be reinstalling the current driver software.
If still a problem, the network adapter would need to be physically removed and replaced.
Hope this helps.
May 20, 2011 | Toshiba Computers & Internet
Belkin wireless g dektop card part no f5d7000ak is not working in windows 7 64bit
If you are using an older Belkin Networking product, you may not have support for Windows 7 with your current software.
Software updates will be posted as they become available. Please check back if your product is not currently supported.
Some updates may still be in the process of going through Microsoft's official certification program. Although they have been thoroughly tested, they may present a warning message when the driver is being installed. These drivers will install on 32 bit operating systems but not on 64 bit systems, which is the normal and expected behavior.
Even though your product may currently not be supported under Windows 7, it may very well work on it; in the majority of cases, software and drivers for Windows Vista will work on Windows 7 without a problem.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | Belkin 802.11g Wireless Desktop Network...
Can Suretrak 3.0 be upgraded to the most current version?
Have you tried looking on there support page?
It should have all the updates, and what qualifying product is needed to be entitled to the latest updates
Jul 21, 2010 | Primavera SureTrak Project Manager 3.0 for...
Are there new drivers for teh Wireless G Plus MIMO USB adapters for windows 7?
From Belkin's Support web site: Windows 7 Product Support Information Windows 7 users:
If you are using an older Belkin Networking product, you may not have support for Windows 7 with your current software. Please visit your product specific support site to check for updated Windows 7-compatible software for your product.
Some updates may still be in the process of going through Microsoft’s official certification program. Although they have been thoroughly tested, they may present a warning message when the driver is being installed. These drivers will install on 32 bit operating systems but not on 64 bit systems, which is the normal and expected behavior.
http://en-us-support.belkin.com/app/answers/detail/a_id/2742/q/network-adapters
Nov 22, 2009 | Belkin Wireless-G Plus MIMO Router with...
Can't update symantac 11
please see to it that the product is genuine
When live update fails, it is most likely due one of the following reasons:
· No license file (*.slf) is installed
· The installed license file (*.slf) has expired
· The trial period has expired
· The installed license file (*.slf) has been deleted, or become damaged or corrupted
· The software is not able to able to communicate with the Symantec servers
It is necessary to have a valid license file installed into the program to authorize it for the download of the content updates using Live Update.
It is necessary to register your license(s) at the Licensing Portal (https://licensing.symantec.com/) to generate the license file if it was not included with your license certificate (*.pdf).
The license file (*.slf) has expired
It is required to have a current support contract to be authorized to have the most current content updates downloaded. If you have renewed your support contract, it is necessary to register your license(s) at the Licensing Portal (https://licensing.symantec.com/) to generate the new license file if it was not included with your license certificate (*.pdf).
This could also be the case if you have a current support contract, but had a trial license key installed in the software. It is necessary to register the support contract renewal to generate the new license file.
Many of Symantec's products offer a limited-time trial period where you can test the software in your environment. When the trial period expires, the software will typically cease to function as part of the Trialware installation agreement.
The installed license file (*.slf) has been deleted, is damaged or corrupted
If the license file that was installed in the program has been deleted or is corrupted, it is necessary to reinstall the license.
You can re-download the license file from the Licensing Portal account the license was registered in. If you registered the license into your Licensing Portal account, you can log into your account and re-download the license file. If the license was registered into the account of another person, you would need to contact that person to have them re-download a copy of the license file or provide you access to re-download the license file from their account.
The software is unable to communicate with the Symantec servers
The Symantec software must be able to establish a connection to the servers to be able to download the current content updates. If the software is unable to establish the server connection, then it will not be able to download the content updates.
You would need to check your network security settings to ensure the network traffic is not being blocked. If you believe your network's security settings might be blocking the Symantec software from communicating to the Live Update servers, contact Symantec Technical Support for assistance. You can find the phone number for your region here: http://www.symantec.com/business/support/contact_techsupp_static.jsp
One example of this occurring is when trying to install a license file into Symantec Mail Security 4.6 or later you get the following error message: "Symantec Premium AntiSpam registration failed. The product will not receive definition updates".
Here is a link to a technical support document with more information on this issue and possible resolutions: http://service1.symantec.com/support/ent-gate.nsf/854fa02b4f5013678825731a007d06af/e0395129f0bedbf4882570d2006ad1af?OpenDocument
(i took it from "http://customercare.symantec.com/app/answers/detail/a_id/81/kw/update/r_id/166" )
Apr 22, 2009 | Symantec Norton AntiVirus 2008: Windows
My internet connection gets lost after shutting down!
Got to control panel. Double click on modem, then driver. Select update driver. Let it search.
Dec 28, 2008 | Microsoft Windows Vista Business Edition...
Computers & Internet Logo
78 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
