Question about Refrigerators
The refrigerator won't turn back on. The display says SA 66
What is the width od a whirlpool fridge model number ET20DK
Hi Dennis:
Looks like the hermit answered this a while back.
hermit58
  • 33 Answers
SOURCE: can you give me the measurements height width
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
Jul 08, 2015 | Whirlpool Refrigerators
Gfe28 fridge with a sa 66 code when plugged in
GE refrigerators and a lot of new appliances have a mode called sabbath mode or SA 66. it turns off your lights and advanced features for the weekend. To exit sabbath mode push and hold light and lock for 3 seconds, or for some models it's light and alarm for 3 seconds.
Jun 30, 2015 | GE Refrigerators
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
Error code 02-66 when I try to use my ipod with my pioneer head unit
I fixed it! I had a working set up. I synced my iPod touch and update the software, then hooked it back upto my car stereo. I received error code 02-66. I disconnected the iPod and cable from the radio. Turned off the radio restarted the iPod. Turned radio back on with main menu displaying on iPod I hooked it back up to the Pioneer radio. Vuala! It works. Hope this helps.
Aug 09, 2013 | Car Audio & Video
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Beer is not chilling and the display keeps blinking
Let me know what you find out. I un plug the thermastate and it stops blinking. If I plug back in. It starts blinking again. Regardless with or with out it plugged in the unit will
not cool below 66 degree's. I think there isosomething wrong with
the cooling agent or the thermastat
Aug 08, 2010 | Krups BeerTender B95 Beverage Dispenser
A/c does not cool properly in the summer. Temp
YOU probably need to recharge the refrigerant there may be air in the lines and its almost empty. REMEMBER after filling the system with the correct refrigerant YOU MUST DISCONNECT THE NEG BATTERY CABLE FOR 1 MINUTE THEN HOOK IT BACK UP or the compressor will not turn on..
Jan 19, 2010 | 2008 Cadillac Srx
1998 kia carnival, radio is not working, display shows ''CODE''
I have a manual for a '99 model - the one with separate radio/cassette and CD model No's;
OK55Y 66 860
OK55L 66 860
OK55D 66 860
3K55L 66 860
2K55D 66 860
3K55Y 66 860
Under "How to enter your password"
1. press power button & "Test" appears for 5 seconds, and blinks for 5 minutes. If you turn the power button off then back on again within 5 minutes "Code" blinks on the display.
2. enter password using the numbered buttons - press button 1 once to let it know it's the first digit, then press button 1 again however many times to bring up the code for the first digit. Press button 2 to let it know it's the second digit, then again however many times....etc. To enter default 1111 code, press button 1 twice,, 2 twice, 3 twice then 4 twice.
3. when all four digits entered (default is 1111) press SEL button and display should say "GOOD"
4.You get three goes, if still wrong after third attempt "HOLD" then you have to leave it for an hour
May 02, 2009 | Kia Sedona Cars & Trucks
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
