My washer want spin after being overloaded. What can I do to reset it?
The washer doesn't spin
Possible that the belt is slipping due to overload, check the capacitor to the motor , check the belt to the motor, check if the spindle is jammed , if so reset the spindle.
Jan 18, 2013 | GE WBSE3120B Top Load Washer
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Is there a way to fix an error f51 code myself...like a reset button
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Keep getting the overload message "OL"
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controler board is damaged and will need to be replaced.
Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
Sep 05, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
F51 code appears and stops the washing cycle.
Aug 08, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't spin
Try a different spin cycle on another setting if it still doest work try removeing the clothes and changing it to a normal wash cycle. If no try unplugging it for a minute or 2 and then back in hopefully it resets and if still no movement on the unit at all you may have overloaded it causing the motor to wear prematuraly and burn up. This is very common with overloading.
Aug 06, 2009 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
