Question about The Video Game Consoles & Games
Hi my lifestyle 5, bose, music centre has a faulty cd player ,it plays first track but not any other tracks. it seems the round plastic fitting on door of cd player is loose/faulty.
The round disc like fitting on cd door seems to be lose . has anyone got advice about self repair or a cheap repairer?
  • 114 Answers
SOURCE: CD player intermittently will not read track when I skip to another track
This might not be a problem with your CD player but with your CD. To check this, if it's easy for you, make a copy of your CD and try it. If the problem is fixed then it was a problem with your CD. If it's not fixed then the problem is with your CD player. Maybe the CD lens needs to be changed or be calibrated by a service technician.
Posted on Oct 08, 2007
SOURCE: CD player skips on early tracks
The lens assembly in a CD player glides along on a two rail track, kinda like a railroad track except tubular. The lens carriage is moved over this track by a small motor driving a worm gear. (Think long, tubular and spiral). If the rail tracks or the worm gear dry up or have dust accumulating on them, this could be the cause. Normally they have a light gear oil or lithium grease on them to keep them lubricated.
Posted on Mar 10, 2008
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Posted on Feb 24, 2009
SOURCE: NAD 5000 CD player
Posted on Oct 06, 2009
  • 9 Answers
SOURCE: my Bose wave radio cd player is having a hard time
you can get it repaired by Bose and call tech at 973 644 2673
Posted on Aug 10, 2011
How can I get track names on wave bose
When you make a cd if the names are not coming in when you add the tracks you can try a feature on most programs which is called get track names or something similar if this does not work you can type them in manually most burning programs have the ability to do this . I have all these features on my burning programs . You would have to import the tracks into a new play list and try what I said bottom line is at the least you should be able to add the track names manually then burn and they will show up on most radios or CD players . Hope this helped
Sep 03, 2014 | Bose & Wave& Music System
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Hi. Hope you can help me out here. Some1 is offering to sell me his NAD C521i CD player. Its been with him for 5 years. Is it wise to get it since it is already 5 years old (at least that i what the guy is...
This cd player sound great but have in mind it is fitted with NE5532 op amps in linedriver stage, but single trafo supply, and this player is a standard production line cd player. I owned one, i liked the NAD sound, and i think if you pay something like $100-$130 you will be happy. Also you ask if you shall be aware of something, in older nad cd player displays is sometimes defect, but easy to fix. Also the laser need to be adjusted often. (as in most cd players.)
Step from track 1 to the last traack fast and back to track 1 again, listen to music parts from track 1, track 4, track 10 track xx.
If the sounud is not choppy, if there are coming sound in both speakers and otherwise it sounds good then i think you can buy it without expecting major problems.
Oct 03, 2011 | NAD C521 CD Player
Cd player starts, but stops play by 2nd track
Sounds like tracking motor and/or gear problem!
Check for a small crack on the tracking gear.
Parts not avalible from Bose though, they'll only
fix as a "flat rate"!
Apr 12, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
CD wont play in my Bose Wave
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc', code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 23, 2009 | Bose & Wave& Music System
Bose lifestyle 5
I cannot exactly solve this issue but I can make a comment based on investigation. Lots of people have this issue but there are very few comments to help solve the issue unfortunately.
I have the same issue and have been able eliminate various things because I have a second complete Bose Lifestyle 5 system.
It is clear the issue does not lie in the Sub and is related to the Music centre unit. I can use a second identical music centre to power my sub just fine and my broken Music centre cannot drive my second sub.
Now the issue is knowing where to track down R428 in the music centre which is the suggested fix to this issue. I have opened my unit and there are resistors various Resistors in the 400 range but no R428.
If anyone can help with the location of R428 in the Music Centre I would be very grateful.
Nov 06, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Wave Radio skips CDs
it seems taht motor that spins the cd is going bad.
Jan 31, 2008 | Bose & Wave& Music System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Homemade mixed CDs on 38
Yes, you can enter you own CD and Track information. First, note the CD number you wish to enter data, then press the System menu button on your Bose RC38T remote control (main). Select Stored and you will find an option to EDIT.
A on screen keyboard will allow you to enter CD/Track Info.
Sep 25, 2007 | Bose Lifestyle 38 System
Video Game Consoles & Games Logo
26 people viewed this question
Top The Video Game Consoles & Games Experts
Deepika Balla
Mary-Ann Silva
Mary-Ann Silva
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
