Question about Simplicity Vacuums
I have a Simplicity Scout. How do you access the bag holder/
How do I change a riccar vacuum bag type z
Attach the bag securely in the bag holder. Slide the bag holder into the groove in the vacuum making sure the hole in the bag lines up with the hole in the vacuum where the hose attaches to.
Feb 10, 2015 | Riccar Vacuums
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
I cant figure out how to put the type Z bag into my canister model Jill
you need to place it in the bag holder. It either slides or clips into the bag holder.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
May 15, 2011 | Simplicity Vacuums
How do you hook a new bag?
The cardboard on the bag slides into the bag holder. Somtimes people throw the bag holder away when empting the last bag.
Bob
eVacuumStore.com
Mar 23, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The bags keep falling off
The nozzle pictured upon which the bag holder mechanism broke on my machine. Took it to Oreck dealership twice and he kept replacing the bag holder, but mostly trying to sell me a new vac.
Problem was, the bag holder mechanism itself was no longer attaching to the exhaust port because a major portion of the attachment device simply went missing. Notice that in the pics I post there is obviously something missing. A product failure. We don't abuse our stuff.
Solution? I drilled two small holes on either side of the bag holder mechanism and then fed a very small zip tip around the mechanism and around the plastic cloth bag holder support so it can no longer disconnect. Key to this is to feed the zip tie from behind the plastic cloth bag holder support so that the fat part of the zip tie does not interfere with the connection of the bag support to the bag holder.
Here's a pic of what I did.
Feb 15, 2010 | Oreck XL Ultra Bagged Upright Vacuum
I have a simplicity 6 series vacuum. the bag overfilled and vacuum will not run. No power. is there a fuse of relay inside the unit?
no just on /off switch and direct power to vac motor sounds like its burned up from bag being overfilled , now you have to get to the vac motor test it with switch on to see if its getting power if so then motor is burnt.use an ohms meter for power test.
Feb 07, 2010 | Simplicity 7250 Deluxe Vacuum
Hi. I purchased a Simplicity Freedom about 2 years ago. I have had it in for various repairs several times. One persistant problem that the repairman cannot seem to fix is the dirt does not fall down into...
You can let the vacuum run alittle longer so the bag fills up with air, also make sure that the bag in on correctly and you have the right bag for the unit. Let me know if this helps.
Oct 12, 2009 | Simplicity Vacuums
Over heating
TAKE IT TO A DEALER HE WILL HAVE THE PARTS FOR IT
Aug 06, 2008 | Simplicity 7850 Premier Bagged Canister...
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Vacuums Logo
27 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
