Question about Vacuums
How do I access the bag holder? - Vacuums
  • 1,830 Answers
What type of vacuum cleaner do you have?
Posted on May 12, 2017
Plastic blue holder inside bag came off,, how do you reattached so I can but the filter bag on
In addition I would add, that the bag must be fully installed on the upper handle mount before attempting to reinstall the clip. I find that the clip should be installed, then squeezed to install the bag holder, being aware of the proper orientation of this part.
Jun 26, 2015 | Oreck XL Ultra Bagged Upright Vacuum
How do I change a riccar vacuum bag type z
Attach the bag securely in the bag holder. Slide the bag holder into the groove in the vacuum making sure the hole in the bag lines up with the hole in the vacuum where the hose attaches to.
Feb 10, 2015 | Riccar Vacuums
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
I cant figure out how to put the type Z bag into my canister model Jill
you need to place it in the bag holder. It either slides or clips into the bag holder.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
May 15, 2011 | Simplicity Vacuums
How do you hook a new bag?
The cardboard on the bag slides into the bag holder. Somtimes people throw the bag holder away when empting the last bag.
Bob
eVacuumStore.com
Mar 23, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The bags keep falling off
The nozzle pictured upon which the bag holder mechanism broke on my machine. Took it to Oreck dealership twice and he kept replacing the bag holder, but mostly trying to sell me a new vac.
Problem was, the bag holder mechanism itself was no longer attaching to the exhaust port because a major portion of the attachment device simply went missing. Notice that in the pics I post there is obviously something missing. A product failure. We don't abuse our stuff.
Solution? I drilled two small holes on either side of the bag holder mechanism and then fed a very small zip tip around the mechanism and around the plastic cloth bag holder support so it can no longer disconnect. Key to this is to feed the zip tie from behind the plastic cloth bag holder support so that the fat part of the zip tie does not interfere with the connection of the bag support to the bag holder.
Here's a pic of what I did.
Feb 15, 2010 | Oreck XL Ultra Bagged Upright Vacuum
This silver metal triangle shaped thing popped out
I think it's a spring that goes on the bag holder itself... You have to sort of pop the bag holder up from it's hinges and see a little tab stick on the bottom, in the middle, pointing sideways. There's a little groove that the spring is supposed to line up with on one side, and if it's not in that place you put the spring on backwards and have to turn it around the other way so the end lines up. Then snap the holder back in, and make sure the spring is pushing against the vacuum so when it's in place, the holder pushes the bag up towards the lid. The spring is to keep the bag pressed up to the air intake, and doesn't push down very much.
Jan 14, 2010 | Miele S318 Bagged Canister Vacuum
Hoover telios Bag holder, fitting
HI The bag holder slips into place by opening the lid and aligning the bottom sections into the slider L shape part just at the mouth of the actual dust bin. Slide the part so that it sits at an angle before the bag slips into it. Once that's done make sure the bag is pushed down otherwise the lid will not close.
Feb 25, 2009 | Vacuums
Taking bag holder off
yes, you should see a clip inside the bag housing unfasten, can be hard, you will see it when you unzip it
Jan 21, 2008 | Eureka Boss 7601 Bagged Upright Vacuum
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
