Question about Canon Office Equipment & Supplies
I have a problem with CANON MF 3010 which prints white print ......... How can I solve the issue
  • Shashank Bhoir
    Shashank Bhoir May 12, 2017
    It is a all in 1 printer , Xerox copy prints white page
  • 111 Answers
SOURCE: Need to install Canon MF 4150 printer on Vista 64 computer
Check the drivers are for your current operating system
1. Go to Control Panel/Printers and Faxes/Add New
2. Follow the prompts then select have disk
3. Go to the directory in which the file is located and double click it
4. Get back to me with your results
Posted on Jan 07, 2009
SOURCE: canon mf 6550 copy no print out its came out empty page
We had the same problem with our mf6550 printing blank pages after we changed the toner cartridge. I called the support desk today and they said it is the shutter. They told me to remove the toner cartridge and then (without a cartridge in) close the door briskly. Then open the door, install the cartridge and again close the door briskly. It worked! He said it may be a permanent fix or it may act up again. He also said I could take it to a service center to have it fixed permanently. The service desk # is 1-800-828-4040. They can tell you where the nearest service center is. Good luck.
Posted on Dec 31, 2009
  • 1219 Answers
SOURCE: Canon IR 2270 The copier print
these means that copier cant detect the toner in developing/toner assy.
You should try to reconnect the toner developing assy and try to vacume it.
Also check if the toner bottle is rotating, if yes that means that toner is being dosed and problem is developing assy.
If you do not want to call service write me on for service manual.
hope that helps!
Posted on Aug 23, 2010
Testimonial: "very helpful i just remove check and reconnect the toner cartrige and the issue is solve "
  • 17130 Answers
SOURCE: Hi, my Canon MP198 cannot
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Posted on Jun 14, 2011
SOURCE: canon mf 4412 Cartridge 328
my canon MF 4412 is power on but coming error E 202 and 0002. How can i solve this problem
Posted on Aug 02, 2011
My canon mf 3010 lasser printer print speed is gating slow ?
My Cannon MF3010 Printing and Photocopy slowly work. How can fix it?
Jul 07, 2014 | Canon imageCLASS Office Equipment &...
Canon image class 3010 slow printting
Hi there:
The main cause of slow printing is due to a bad print cartridge. To troubleshoot this please remove one of your cartridges and see if your printing speeds up. If that does not work. Replace the cartridge and remove the other cartridge. If your printing speeds up. That print cartridge is at fault.
Apr 16, 2014 | Canon LBP2900
My canon mf 3010 printer is blinking red light
I out of paper jam & try this print so not working on printer& blinking the light,please help me..
Jan 19, 2014 | Canon ImageCLASS MF3010 - Multifunction ...
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
How to remove paper piece jam in canon mf 4320-4350
I printed on a thick (photo) paper and then started printing on normal paper. The problem was solved.Thank you.
Apr 24, 2012 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon MF 4150 is skipping, leaving white space and compacting other lines
It sounds like a toner issue. I know that may sound obvious. Have you tried taking the toner cartridge out and shaking it side to side then replacing?
Nov 12, 2011 | Office Equipment & Supplies
I can't print in color!
You probably have the printer to print in "grayscale". Find this option and turn it off.
Sep 03, 2009 | Office Equipment & Supplies
Canon Printer not printing
Clean the heads, the printer is not reading cartidges. Is yours a model that needs the ink levels reset to funtion correctly, then do this too.
Feb 13, 2008 | Office Equipment & Supplies
57 people viewed this question
old marine
old marine
