Question about GPS
Does the M68C have batteries in the unit itself?
TURNS ITSELF OFF
Sounds like the item may have OVERHEATED [will automatically switch off to protect itself from destruction]. Should re-set itself when the internal temperature returns to normal ... [My TOMTOM does the same] ... ok
OR you could have a FAULTY BATTERY or CHARGER. Both of these will cause most GPS units not to boot up or to rapidly shut down [low battery].
NB: Mobile GPS units of any kind should NOT be left mounted on windscreens in a locked car [particularly in direct sunlight] as the inside temperature can rapidly reach over 100deg AND possibly destroy your unit internally.
Nov 19, 2013 | GPS
The plug in to the M68 is crumbling away. now will not power up.
Mine is having the same issue. I wrapped it with electrical tap around the outside to hold the pins inplace temporarily. Anyone know if you can buy just the plug or do you have to buy a whole new transducer?
Oct 10, 2010 | Lowrance M68C SMAP w Single Frequency...
The unit will not turn on (Lowrance M68-C)
hey Jv,, Unless you have all the electrical specifications for each/all the circuits, etc..etc.. I doubt there is a chance you can.. .
Lowrance Service Repair Centers
Jun 27, 2017 | Lowrance M68C GPS Receiver
APC Back UPS Pro 650
since the unit is not rusted ,its clear that it is OK!when battery leaks,it loses power,so is not harmfull to unit.replce the battery and keep rollin!
Aug 21, 2008 | APC Back UPS 650 (APWBK650MC) UPS System
Garmin C330 resets itself
The first problem with it powering itself off is a battery problem. Your battery is not hold a charge.
The second problem with it powering itself on with the power cord attached is a power cord issue. The unit is suppose to automatically power itself on if a power cord is attached to it. This is Garmin way of turning the unit on when you start your car. Most auto cigarette lighter will cut power if the ignition is off, and restore power when the ignition is on.
Garmin uses this to turn the unit on and off. If the unit was being powered by the the cigarette lighter then it say unit is shutting down in 20 seconds after the power is cut.
Jan 21, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
