Cant get acquos wired connection setup to set up wifi,it says you can not adjust these settings while using connected tv features.Exit from connected tv features to make changes to network settings
  • 15 Answers
SOURCE: IPAQ Rx 3715 Internet settings~ conectivity problem
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
http://www.freewareppc.com/communication/hitchhiker.shtml
Hope it goes well! I'll try again if this does not work!
Posted on Mar 01, 2008
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
Posted on Apr 20, 2008
SOURCE: cannot connect to internet via wireless
my phone dont want to connect to intrnet
Posted on Aug 04, 2008
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
ethan859
  • 19 Answers
SOURCE: Liksys WVC 200 doesen't transmit video on WiFi.
Since both the camera and router are Linksys, have you tried Network Magic? You can download the variant you want from here: http://www.purenetworks.com/download/
Posted on Nov 09, 2009
Need help with my L46E5390FE tv on how to connect to internet
View that your wired connection is set to "Connected". This is not an option that you can adjust. It is for information only. "Manual setup" is available. Select to view and/or manually change your network settings, and then click on "Test Connection" to make sure your wired ethernet connection in tv is working.
Dec 03, 2016 | Televison & Video
How to connect to wifi on my new tv don't no what to do l have ready for connection.to get started launch wireless display on your device can't find wireless display
On the smart tv's you can connect to wifi.
  1. Connect the wireless adapter to the USB port on your TV.
  2. Press the MENU button, and then select Setup.
  3. Select Network.
  4. If Network Type is set to Wired, select Network Type, and then select Wireless.
  5. Select Network Setup.
  6. Select Select a network.
Jul 29, 2016 | Computers & Internet
I want to connect my tv to wifi but i couldn't find the setup menu
first your tv needs to be a "smart" type tv set this has both a wired network connection and a wifi connection if it does not have this you will need a converter , you will need your routers password , as you will need to authorize the tv in the routers set up (yes even if you have a dhcp router ) , turn tv on if your using a universal remote most times they cant access the tv set-up menu (on purpose ???) anyways find the tiny buttons along edge to set id bet its near the power button , till you find "menu" press this it will bring up a new screen on tv , use your up/down arrows on remote to go to network , press enter on remote this will bring up a new screen , select "enable" on wireless network an press enter key , this will bring up a new screen it should after a few minutes show a list of routers It can "see" select your routers name using up/down arrows on remote and press enter , a password prompt should show up , enter the network password (from router) and press enter when done , takes a few moments but it should finally say connected (if you did it right ) then exit out of this and bring up "browser" from your menu , this will look like a normal pc browser an you can enter your destination from there , this is a general set up method your tv might be slightly different but this shows suspected path to follow
Jan 22, 2016 | Televison & Video
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
How do you setup scanner
It _must_ be setup via USB cable before any Wifi features can be used. Try connecting USB cable, then turn on scanner, then set up for use with computer... Then you can disconnect the USB cable and use the Wifi feature.
Aug 15, 2015 | HP OfficeJet 6110 All-In-One InkJet...
When I run the wireless setup on my Samsung PN518000 plasma tv it times out and does not obtain the necessary IP information. Does the community feel replacing the wifi module in the TV will fix this...
did you check out the menu setting for wifi setting first
then check too see if there is something mode wise isnt right
i would setup a hot spot on your phone and try that
if it connects to the phone and not too your wifi
then atleast you can rule out the TV
cant seem to find too much info on this unit
Dec 09, 2014 | Samsung Televison & Video
I was given Netflix (stream-in) for a gift, but can not get it to come onto our tv. Please help.
Your TV must be a 'smart' TV i.e. it should have software enabling it to connect to the internet and access features such as Netflix. If you don't have a 'smart' TV then you can purchase a set top box which can be connected to your TV and will allow you to access on-line services such as Netflix. If you have a 'smart' TV then you still need to connect it to your internet router, either with an Ethernet cable or via WiFi if the TV has WiFi built in (or you can buy a WiFi adapter for the TV). If you connect with an Ethernet cable then the TV will connect to your router (and internet) with no further setup. If you use WiFi then you will need to access the WiFi settings menu on the TV and configure the settings for your router.
Jan 19, 2014 | Computers & Internet
How do i connect my DIR-142 to my ps3.
try to use port forwarding, Just go to your routers webpage, then advance and look PORT FORWADING option, set the port for your PS3 then assign an IP on it then save and exit. Hope it helps thanks.
Sep 22, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
How do i connect my pc to my tv
Yes it supports PC hook up. You can hook it in four ways using either an S-Video, HDMI or DVI connector.
  1. Connect the PC to your TV using either of the above connectors.
  2. Press MENU on the remote control and FEATURES > MODE SELECTION.
  3. Select PC and press OK to confirm your choice.
  4. If necessary, adjust picture settings.
  5. Set the picture format to Unscaled when using wide-screen PC resolutions.
  6. Press MENU to exit.
Oct 08, 2009 | Philips 47PFL3603D LCD TV
Computers & Internet Logo
David Payne
David Payne
