Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
Dropped unit from about 3 feet on driveway. cannot start now
I was taking my weedeater to put it up when I dropped the unit on the driveway. It dropped approximately 2.5 to 3 feet. Since then I have not been able to start the weedeater.
    President:
  • 1,273 Answers
Check for spark. I dropped one once, and it turned out to be a cracked spark plug electrode.
Best regards, --W/D--
Posted on Jul 25, 2009
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
How many square feet in a ten foot wide by 500 feet long driveway?
You just multiply the one against the other
500 x 10 + 5,000 square feet.
Divide by 9 to get square yards. = 555.6 sq yds
Feb 01, 2016 | Home Fencing
How to get rid of the dark spot in front of the car when the headlight is turned on? Is there any adjustment for this?
Headlights can be aimed, and after a bulb replacement they need to be. You can aim them, all it takes is night and a screwdriver. Rule of thumb:
Single headlights on each side, should be aimed to drop straight ahead and drop 2 feet per 100 feet. Dual headlights on each side, drop 1 foot per 100 feet.
It helps to have a level, 100 foot driveway or quiet street to aim. . .
Sep 12, 2014 | Cars & Trucks
Put my 1995 jeep wrangler in 4 low to see if it would help when reversing up a snow covered driveway...transfer case shifter won't move out of 4 low...pulled back out of driveway and drove a couple of...
your transfer case shifter is locked on 4 low get under take a look at your sifther link shaft, get a long regular screw driver and push the link-shaft up, to release the gear.
Dec 14, 2010 | Jeep Wrangler Cars & Trucks
I need to know how to change the trimmer line on a weedeater RT112C
REPLACING THE LINE
1. Disconnect the unit from the power
source.
2. Remove the spool by firmly pulling on the
tap button.
3. Clean entire surface of hub and spool.
4. Replace with a pre-wound spool or cut a
length of 30 feet of 0.065′ (1.65 mm) diameter
WEED EATER brand line. Use of
heavier lines could overload and damage
unit.
Also here is the manual if you need it.
http://dl.owneriq.net/5/56bed657-13ad-4194-85f3-2c4890bcfd6d.pdf
Good luck
Sep 25, 2009 | Garden
Car died then restarted three times
Run a scan tool to determine problem, if nothing found take the car to the nearest acura service center to check for any recall onthe car.
Jul 09, 2009 | 1997 Acura TL Series
I have a weedeater brand weedeater and need to know how to take the spool off so I can wind more line on it?
if its the newer type all you need to do is grab the black knob at the bottom of the trimmer head and pull it carefully straight towards you and it should pop off
wind line on the spool in the direction the arrow shows you there is a small hole you put the line in to start the line before you wind it it is labeled .065 or .080
wind about 10-15 feet of either .065 line or .080 line and lock the line in at the edge of the spool and thread the excess thru the hole and push spool back on and pull each line until it unhooks from where you locked it in .
this is the directions to the weedeater heads and spools mostly used on this product.
if its two lines then pull out 20 feet of new line cut it and put the two cut ends side by side and insert the cut ends into their respective holes in the spool and wind in the direction of the arrow until you wind to the loop then cut the loop lock your lines into place and thread it thru both holes keeping the lines kind of tight and push the spool onto the housing as it snaps in pull each line to unlock it from where they were held so the bump feed will work.
hope this helps you
Jun 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
120 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
