Question about Husqvarna Garden
Garden tractor. A.Y.P American yard pro
Need a exploded view of fuel pump mine is mechanical not vacume which I may switch over too its a Kohler 20hp. Magnum M20qs and another set of numbers 49603. Thx. Tony
    Top Expert:
  • Husqvarna Master
  • 35,672 Answers
Request the exploded view from the manufacturer/distributor.
Posted on May 13, 2017
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 133 Answers
SOURCE: I need a drive belt diagram for a 1974 john deere
I don't have a diagram but it shouldn't be to hard. You will have to drop the deck. Then when installing the new belt remember to always place the inside of the belt (V) into the pulleys and the outside of the belt (flat side) up against the larger idler pulley. When you have the belt on properly it should be snug. If you have excessive play you need to try a different routing around the idler.
Good luck and let me know if this helps.
Thanks
roundo4
Posted on Sep 06, 2009
harlan301
  • 205 Answers
SOURCE: Tractor won't start. Acts fuel starved.
you can to this in two ways. pull the out put hose off, turn the engine. be vary careful, to see if fuel comes out. or do a pressure test about 3 to 5 pds. check the tank. I have seen flays and other ?? in the tank plugging the lines. blow air throw the lines (not the pump)
Posted on Oct 13, 2009
  • 203 Answers
SOURCE: how do i drain gas from 20hp 42in yard tractor?
The best way will be to take the fuel line off the carburetor or off the fuel pump, if so equiped, and put it lower than the fuel tank on the mower. Drain into a gas container. You can then put this gas in your vehicle to burn, rather than let it sit and go stale over the winter months.
If you are just taking the fuel out for the winter, and not for any other purpose, you can purchase some fuel stabilizer, called "Stabil", and put about 2 oz. per gallon of gas that's in your mower tank. Slosh it around a bit, start your mower and let it run, or take it for a spin around the yard to make sure you get the stabilizer mixed in well and down into your carburetor.
If you do drain the fuel for the winter, after you are done start your mowers engine and let it run the carburetor dry. That will keep it from evaporating too bad and gumming up your carb. Still a good idea to run some stabilizer thru the carb prior to draining the tank.
Posted on Oct 26, 2009
  • 4 Answers
SOURCE: need exploded view of Husky Pro HVLP HDS890....
The gun was made by Campbell Hausfeld. I had the same issue when it was new. The shipped me the parts free of charge. The below link will take you to what you need. I realize this is a late post, but others may need it as well.
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=hds890
Posted on May 02, 2010
Kohler engine troubleshooting
Do you hear the fuel pump running? Is there gas coming out of the pump? Could be a bad wire connection to the fuel pump or bad ground connection.
Aug 03, 2014 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
My husqvarna kohler yth21k46 is 2 days old and i turned it on ran for 20 mins and smoke came out from engine gas leaking from bottom of the air cleaner thought it was going to explode . what should i...
After reading your question it sounded like the smoke was due to fuel leaking on the muffler and or excess fuel entering the combustion chamber. I would due the following diagnostic. In a quite area turn on the ignition switch. You should hear the metallic click of the fuel cutoff solinoid on the carburetor.
Mar 20, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Jul 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas in the crankcase
need to do compression test to test piston rings and check carb float possible sticking allowing fuel to keep flowing
Apr 08, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Tractor won't start. Acts fuel starved. I see very little fuel in the filter which is new. I suspect the fuel pump assembly is bad. Any easy way to test the pump? 20hp Kohler engine.
Oct 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a Sears 42" deck mower. It keeps stalling. Sometimes uphill but also on level ground. Gas in filter is present yet just shuts down. What could this problem be?
Most likely this is a fuel pump problem or a float problem in the carburetor. Most carburetors can be cleaned and rebuild but most owners will not
have the proper equipment to do a thorough job. Take it to a good
servicing dealer for his advice and estimate. Sometimes there is a
gasket or a valve problem and a good experience mechanic can
tell a lot by just listening to the engine for a few seconds.
Sep 13, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
I get a vacum lock on the fuel
sounds like you need a new fuel cap as its pulling a vacuum on the tank and not letting fuel flow! also double check thats theres no debris in the tank to stop up the outlet
May 04, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
