Question about Refrigerators
JFI2089WTS0 refrigerator door control panel removal
3 Suggested Answers
SOURCE: amana refrigerator freezer access panel removal
As a plumber... I would initially want to see if it is indeed a leak from the water line. You have defrosted, so there would be water at that time and a short period thereafter. You have had the unit off for two days so it's not been able to "generate" any more ice or even had a chance to malfunction and "try" open the solonoid valve and allow water into the ice maker or water dispenser.... All that being said...
I suspect the water you're see is ultimately from the incoming (pressurized) water line... probably not from the actual ice make line coming into the fridge, but more than likely somewhere "within" the piping of the fridge itself... its very possible something was accidentally damaged during the previous process you just went through-- especially if you removed the door to the freezer. Many fridge's have the water line come through the lower side hinge of the freezer door, not sure if this is true in your case.
Hope this helps, if not it may be applicable to someone else... good luck!
Posted on May 18, 2012
Sea Breeze
  • 4654 Answers
SOURCE: How do I remove the front control panel on the GE
I believe this manual HERE will instruct you beginning on page 53. Correct me if I am wrong, Thanks John Tripp Appliance 911
Posted on Feb 14, 2014
Snowmaster BD60DE keeps on beeping while doors are shut
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Chimes constantly. How do you turn them off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
How do I replace the battery in the control panel
Hello friend, thank you for your post!
I see that your question is listed under Frigidaire refrigerators and you are looking to replace the control panel. There is not a guide to removing the panel out of your refrigerator but if you are able to provide me with your model number I can see if there is any additional information. Usually you can locate your serial tag (which lists your model number) on the inside wall of your refrigerator on the right hand side. I look forward to assisting you. -Matt
Sep 11, 2014 | Frigidaire Refrigerators
How do I get my refrigerator to stop beeping
Sep 10, 2014 | Samsung RF4267HARS Stainless Steel French...
Front panel, temp control, water, ice etc not working.
Can you explain more about the panel?Email me through this website at "skyethespy@att.net" no quotations
Mar 09, 2014 | GE GSS25IFR Side by Side Refrigerator
My refrigerator section is not staying as cold as it should. what causes this?
There is a fan located behind the inside rear panel of the freezer first thing to assure is that the fan is working simply by listening or removing the panel in the rear of the freezer can assure the fans operation. If you find an ice build up on your evaporator coil when you remove this panel this is known as a defrost issue in which if you did find this message me back for further diagnosis. A defrost issue is caused by either the defrost thermostat which is the most common faulty part the defrost heater or the defrost timer or adapative control board. But getting back to the refrigerator side of things the air that comes from the fan goes through a small door known as the diverter or damper door this door opens and closes inside the refrigerator letting cold air go into the refrigerator side of the unit. Usually it has a control located in the ceiling of the refrigerator which is termed as a thermostat control usually found on the dial that controls how cold your refrigerator gets. In order to solve this situation you would remove the diverter door and inspect for ice up on the door fins if there is no ice up then the issue would most likely lie in the thermostat control for the door. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
Jul 26, 2011 | Kenmore Refrigerators
My Refridgerator is not cold (60*). When I open the freezer door I do hear something running. What could the problem be?
Is the freezer cold in the unit if the freezer is cold but thhe refrigerator is not you would next look at the air flow is the fan inside the freezer running there is a small fan located behind the rear panel inside the freezer you would remove this panel in order to access the evaporator coil and the evaporator fan as well. If you put your hand inside the rear of the refrigerator you should be able to feel air blowing through a small door. That small door is called a damper door and there is a control located in the ceiling of the refrigerator that controls the door. the control is attached to the control that you use if you wanted to make the refrigerator colder. Around this time of year as it gets hot I do find alot of these damper doors and damper door controls that go bad. Matter of fact I just had to change on out today at a customers location. If you have any further questions message me back also if you remove that rear panel inside the freezer to assure that the evaporator fan is running and you see any ice build up on the evaporator coils message me back on this as well this is known as a defrost issue and I would have to further instruct on how to alleviate the defrost issue. Also please remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks
Rick
Jun 29, 2011 | Kenmore Refrigerators
NEED TO REMOVE DOOR HANDLES
hello,
this are the instruction to follow below
1.Check out how the door panels are attached to the car. Most panels usescrews and bolts but others have snap-in fittings. Gather all the toolsyou need for removing the door panels. If the panel is attached withscrews and bolts, you need a screwdriver or ratchet and socket. Cardoor panels with snap-in fittings are easily removed with a flatheadscrewdriver.
2Locate where the screws and bolts are before starting. These areusually found in the arm rest area, along the bottom or sometimes nearthe door lights.
3 Roll down the car door window. Begin removing all screws and bolts thathold the door panel onto the car. If your car has snap-in fittings, prygently on the bottom corner of the door panel until the fittings popout.
4.Remove the power window control panel if your car has power windows.The control panel should pry out easily, and then you unplug the wiringharness from the back and place it to the side.
5Use an L pick and flashlight when locating a manual window crank. Lookbehind the window crank and slide the pick under the edge of the metalclip that holds the crank in place.
.Remove the clip and pull the crankoff.Remove the door handle by unscrewing the small screw located in thecenter. Gently pull the door handle out until you see the back of thehandle and unclip the rod from the door handle. This should remove thehandle unless the handle and door lock are attached, then you justunclip the rod from the lock and remove them both together.
7.Unscrew the cap off rear upper corner doorpanel locks. These don't have a rod attaching them to the handle andunscrew separately from the door handle.
8.Pop the door panel off after you've removed everything. Gently pry onthe bottom edge of the door panel until it releases. Pull out and up tocompletely remove the door panel.
please do all this instruction with care thank and
thanks for using fixya.
  • Step 8 Pop t
  • Read more: How to Remove Car Door Panels | eHow.com http://www.ehow.com/how_2164577_remove-car-door-panelsremove-car-door-panels.html#ixzz0vxRgii6t
    Aug 07, 2010 | Whirlpool ED2FHGX Side by Side...
    Replacing Light bulb in a Frige
    Open refrig door, look at control panel, on each end of control panel there should be philip screws holding panel, remove screws, drop panel down slowly, replace light. Install in reverse order.
    Oct 16, 2009 | GE PTC22MFM Top Freezer Refrigerator
    Control panel inactive
    Your refrigerator is in demo mode. Review your manual on how to remove it.
    Feb 24, 2008 | Samsung RM255LASH Side by Side...
    Refrigerators Logo
    27 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
