Question about Coffee Makers & Espresso Machines
After several years of use, mocamaster 10 cup has started to drip condensation from brew basket lid outside the brew basket. Water is dripping on to the counter top. Counter top is level.
dragonsthatk
  • 547 Answers
SOURCE: The vent on front of door expels steam in drying
change the seal around door
Posted on Feb 18, 2009
  • 20 Answers
SOURCE: Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
Posted on Aug 14, 2009
  • 4 Answers
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
  • 1089 Answers
SOURCE: saeco stratos coffee maker started to leak inside
HI
There are a lot of things that can cause the machine to leak.
You could have a fitting or tube that is broken.
You boiler could be leaking and needs to be replaced.
You could have a hose connection that has come loose.
You could have a bad seal at a connection.
Until you get inside you will not know? You might want to have someone look at it for you.
Scale is one of the major causes for machines to start leaking. Make sure that your water hardness is set on 4, so you descale more often than not enough, to prevent leakage in the boiler.
Posted on Nov 07, 2009
  • 19 Answers
SOURCE: our machine is not dripping the coffee into the
you need a tune -up estimated costs about 175.00 contact me www.lavazzarepair.com
Posted on Dec 11, 2009
Why does coffee come out while pouring in water its a bunn 10 cup coffee maker
The Bunn has a little stopper that closes the water drain port in the reservoir while the lid is open. You can see a little white plastic pin protruding up out of the grate with the lid open. When you close the lid, it pushes on that pin which causes the stopper to lift off the drain port, allowing the water in the reservoir to enter the heating tank.
If water is entering the coffee basket BEFORE the lid is closed, then something is wrong with that little stopper. It may have a chunk of debris on it preventing it from sealing, or it may be deteriorated, torn, disconnected, etc.
Only way to know is to remove the the screws in the grate and pull the top off exposing the reservoir, and the stopper assembly. The little plastic flapper disc should be seated in the reservoir drain port. It should be relatively flat (not wrinkled) and covering the drain port completely. Test it by pouring some water into the reservoir. If it drains out without you activating the stopper, then a repair is needed.
Move the lever up and down and check its operation. The arm must move freely and close when released. There should be no dirt or debris on the sealing surface of the flapper nor on the sealing surface of the drain port. Gently clean with vinegar as necessary. If the seal is damaged, then a replacement is required.
Nov 29, 2014 | Bunn 10 Cup Home Coffee Brewer
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker with grinder--sometimes, when percolating, it overflows
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
My cuisinart brew and grind overflows onto to the counter also
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
8. Clean your carafe and machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water spots). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
Jun 27, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
My grind and brew turns itself off in the middle of brew cycle
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart model dgb drips very slowly
Clean with vinegar.water. Also, make sure the filter basket is not damaged (easily replaceable).
Oct 29, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Water/grinds spillover in coffee basket
Pot must be inserted with the handle pointing straight out the front so it will hit the valve that is below the basket designed for the "rob a cup" while brewing feature.
Calvin
Aug 13, 2008 | Coleman 5008C700 Camping Coffee Maker Free
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
