Question about Electrical Supplies
I want to no how you connect a generater to an already wired unit without any mains supply
  • 4,300 Answers
Electrical safety is the main concern and if the unit is a dwelling or a workspace it is important to comply with local safety regulations applicable to the unit.
In addition to the above you should read the generator operating manual thoroughly. Few generators are intended for extended use and increased maintenance might be needed. Some generators require a safety earth or ground fitting for some applications, such as using with metal bodied single insulated tools. Certainly an rcd safety device should be included to protect users of the power generated.
You don't describe the generator at all. If it is a portable generator it will be fitted with power outlets so a connection can easily be made. A suitable cable should be hard-wired into the electrical distribution board of the unit and a suitable isolator switch provided. Depending where you are the unit electrical wiring might not be simple and straightforward as expected and it is important it is connected correctly and made compatible with the generator. A local electrician would be advisable....
Posted on May 12, 2017
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
We changed the thermostat in our unit and now the pilot lite won't stay lit!
You have to check the following:
1. Does the pilot flame has the ability to heat up the thermopile? Themopile must be properly heated in order to generate voltage to open the pilot valve as well as main valve.
2. When the thermolpile is heated, does it generates 500 millivolts? If not, your thermopile needs replacement. If it does and still the pilot flame wont stay lit, your gas valve needs replacement.
3. Does the hi limit device has continuity on its terminals? If there is no continuity on hi limit terminals, you have to replace it. One of the thermopile wire passes on this hi limit terminal to cut the voltage supply on pilot valve in case the oil temperature reaches 450F.
4. Check and tighten all wiring connections, millivolts generated by thermopile will not pass on loosely terminated wiring.
Jan 12, 2011 | Pitco Frialator 35CS Deep Fryer
Can i have all the basic details of UPS system
UPS come in two types, lower powered cheaper types are usually switch over power.
These units senses a power outage and then switch over to the battery power to generate mains supply. The switch over occurs in milli-secs and does not affect the computer.
True UPS types constantly run off battery power to generate mains supply so there is no switch over time lag. These units are higher powered and higher costs units.
Both type of UPS have the same components.
Battery charger.
Inverter that converts battery voltage to mains voltage
Electronic controls
Dec 16, 2010 | Emerson PowerSure Personal 500VA...
My power windows do not work. The Haynes Repair Manual mentions that it could be that a circuit breaker was tripped and might need to be resetted manually. Where and how do I manually reset the circuit...
i have diagram for accord 1993, i cant see the breaker you mentioned, if your relay is ok, its mean that fuse #15 have power 12V and when the ignition is on, the relay have supply 12V to fuse #33, if all this ok, the problm is on your power window main switch, connect a wire supply by 12V to white/yellow wire at power window main switch or test this wire if already have 12V when ignition is on
Jun 26, 2010 | 1993 Honda Accord
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
When i print using my docuprint 203A fuji xerox, the printout result paper was cover with black all over. what does this mean?
This is a rebadged Brother Printer.
Possible causes for a solid black output:
1 Corona failure
Is the corona wire dirty?
Clean the corona wire with the wire cleaner.
2 Corona wire broken?
Replace the drum unit
3 Are the charge electrodes between the printer body and
the drum unit dirty?
Clean both electrodes.
4 Harness connections?
Is the laser unit connected to the main PCB correctly?
Connect the harness between the laser unit and the main PCB
5 High-voltage power supply PCB failure
Is the problem solved after replacing the high-voltage
power supply PCB?
Replace the highvoltage power supply PCB.
6 Main PCB failure
Is the problem solved after replacing the main PCB?
Replace the main PCB.
7 Laser unit failure
Is the problem solved after replacing the laser unit?
Replace the laser unit.
Good Luck!
May 12, 2010 | Fuji Xerox® DocuPrint C3055DX Laser...
Heater isnt wired up but flame part works
It sounds as though you are going to have to trace through your unit's components and wire it without a wiring diagram specific for your fireplace.
Here is a Installation & Troubleshooting Guide for another electric fireplace that includes a wiring diagram. Perhaps this will help? Check it out and request additional help if you have any questions.
Without being there onsite with toolbox in hand, I hope this information is very helpful to you moving forward. :-)
Mar 28, 2010 | Heating & Cooling
Where to connect fire alarm to a combination starter with a hand/off/auto/switch
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Sep 13, 2009 | Heating & Cooling
Zanussi zce 7690 main oven not heating up. everything else works.
Thought someone may find this helpful. We bought our Zanussi ZCG7690XN just 4 yrs ago. For nearly 2 yrs the main oven control stopped working. Never got round to replacing the timer controls- ~£80 or so. Read through some threads and thankfully found a few helpful. What I found difficult after accessing the control unit was recognising the correct wires to connect so as to isolate(over ride) the timer unit. Finally sorted this and presto it worked. The same process may help those who wish to replace their unit with a new one.
For those who will try, take safety precautions. If the spark generator works, there is likely power to the timer unit (and oven). If not check fuse, confirm mains supply.
The control unit is accessed first by unscrewing top oven front plates to gain enough room. Then with a flat screw or similar tool, take off the two small clock knobs and the two adjacent burner dials. you would then need to undo four little screws two on each of the burner dials. You can now gently extract the controls from below -can be tricky, (may or may not require using a plier to bend a bit of metal). With the unit out, turn it upside down and you would be looking at the rear of the circuit board with a blue wire, two brown wires connected to the relays and a red wire feeding back to the main oven dial(beside the spark generator). A green earthing is attached to the side . Leave this alone. All you need to do is to join the red wire to the nearby second brown(live)wire. I did this using connectors. Any other sensible means should be fine. The blue wiring returns to the light bulb and back with the others to electrics at the back. I took this off the timer as well.
I previously had recurrent problems with the grill spark unit connection- burnt off. Sorted this out by fixing the connection (access from the front top oven, unscrew a small metal protecting plate to reach it).
I do apologise if some find this too lengthy. Any questions are welcomed.
Jul 30, 2008 | Zanussi Kitchen Ranges
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
