Question about Acer Computers & Internet
How do i connect my acer wireless mouse to my acer chromebook? The battery is not dead, bluetooth is enabled.
There are two options when i open the blue tooth tab on my chromebook but neither match the information on my mouse. The mouse works on my dell laptop.
computafixa
  • 317 Answers
SOURCE: Printing wirelessly to a Canon MP600
1) you need it to print from a laptop if you do not want to have to set up another computer, and mobile phone have bluetooth buit in
2) YES
3) set up the printer on another computer, and set it for sharing. Then make sure that you laptop is recognized in the network connections wizard, then on the laptop select add new printer and select the bullett that say a network printer. the rest is pretty easy, select browse for a printer or something, it is the first option, select it, say yes to all dialogue boxes, and let the computer do the rest.
EASY PEAZY LEMON SQUEAZY
Posted on Feb 05, 2008
  • 13433 Answers
SOURCE: acer aspire 5610 internal blue tooth connection
Turn the laptop upside down, its one of the covers that is openable with a normal + screwdriver. One of them has the memory other has hard drive and the 3rd should have the addon cards.
Id have to find a service manual to confirm this. But this is how it is in most acer laptops and I have repaired a few.
Posted on Apr 05, 2008
yooperbud
  • 8637 Answers
SOURCE: dell wireless keyboard and mouse will not work
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Posted on Jan 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Hello, acer 5535 Laptop, internal bluetooth problem
your laptop uses a foxconn bluetooth set. Make sure you have the proper driver for this device. Go to Acer support and make sure the driver is up to date. May look something like this:
Fox_brm_2.0 F/W 300
I believe this laptop is still using the bluetooth standard 1.1, so there shouldn't be an issue with finding another bluetooth device. Just make sure that the other devices are in discovery mode or they won't be seen regardless. Discover mode should be able to be accessed through the options tab under bluetooth. Good luck, ParrotHead PC Repair
Posted on Sep 06, 2009
SOURCE: How do I enable bluetooth in my Acer Extensa 4420-5963
Actually Acer use the same laptop case for some of their models, so the acer 4420 doesn´t have built-in bluetooth, you won´t find any driver for the bluetooth cause that reason. I have an extensa 4420-5910, have a bluetooth switch in the case but no bluetooth, if you check at Acer´s web page it say thet some models doesn´t have built-in bluetooth but the switch is in the laptop case... On the other hand, if you install an external bluetooth device, the case switch will be usefull to turn it on and off.
Posted on Oct 02, 2009
How do i use the staples wireless optical mouse with my chromebook?
Wireless mouse and keyboard are supposed to work on chromebook. It is supposed to work just by inserting USB dongel in port. If won't work, test it on a Windows or Mac computer. Wireless mouse and keyboard are supposed to work on chromebook, see customers report at amazon
Amazon com Customer Reviews Logitech Wireless Mouse M560 for Windows 7 8...
But, if works on Windows, it simply won't work for chromebook. No way!
Mar 10, 2015 | Staples Wireless Optical Mouse, Silver
How do I connect a wireless mouse to my nextbook 10.1
You can use only a Bluetooth-enabled mouse with your Nextbook. Make sure your mouse is Bluetooth-enabled and then connect it to your tablet as per the instructions in the set up guide that came with the mouse.
Dec 22, 2014 | Nextbook Tablets & eReaders
Can you use a mouse with the chrome book?
Which specific Chromebook do you have? The Samsung Chromebook has USB ports on the back of the unit (below the hinge for the screen). The Acer C720 Chromebook has one USB port on each side. Most basic mice should work. (Some gaming mice and mice with unifying adapters might have issues.) Some report needing to disconnect and reconnect the mouse after turning on the Chromebook to get it to work. Other models can connect to a bluetooth mouse, like this: http://www.amazon.com/Logitech-Cordless-Optical-Bluetooth-Charcoal/dp/B000BDH2Y8 . Enable Bluetooth and then synch the mouse using the PIN provided in the documentation.
Please note: adding these external devices may reduce the length of time that you can use the Chromebook before recharging the battery.
I hope this helps.
May 12, 2014 | AOL Computers & Internet
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
My hp wireless optical mouse stopped working, even with new batteries. please provide a DETAILED step-by-step process for resetting it. i know it involves pressing buttons on the bottom of the mouse and...
namastey!
*clean the bottom of a mouse and if the lens gets dirty wipe it with the soft dampened cloth
* replace the batteries
*Reinstall wireless drivers. If your mouse came with a CD, re-insert it into your computer's disc drive and install all software and drivers.Disable internal transceiver. If your wireless mouse connects to an internal Bluetooth transceiver, disable it using the Bluetooth utility in the Control Panel, and then re-enable it after a few minutes. Then try connecting your wireless mouse.
Aug 22, 2011 | HP Wireless Optical Mouse
How to connect Microsoft Bluetooth mouse 5000
Please refer to the below KB article, this will help you.
http://support.microsoft.com/kb/952818
Please rate if you like..Thanks
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
Describe how I use wifi on my acer notebook
Click on the "Start" tab on the main desktop screen of your Acer and a list of options will appear in a drop-down menu.
Select "Connect To" from the list of options in the menu.
Select "Show All Connections" from the list of options that appear. A window will open with a list of icons.
Use your mouse to right-click on the "Wireless Connection Icon" and select "Enable" from the list of options. Wireless capability will then be turned on.
hope this helps :)
May 19, 2011 | Acer eMachines 350-2074 Netbook
Dont know ifr i can use a wireless mouse on my acer 110
You can use a wireless mouse. You can buy a microsoft wireless mouse and if your acer comes with a bluetooth option then you can buy a bluetooth mouse to save on usb ports.
Please don't forget to rate me and vote for me.
Mar 23, 2010 | Acer Aspire One PC Notebook
My bluetooth mouse used to connect but now it doesn't...When I press the blue button, the blue light does not blink like it used to. Is my bluetooth mouse dead? (fresh batteries, and it turns on).
Mostlikely you need to repair the mouse with the computer. open your bluetooth utility or the keyboard/mouse utility and follow the pairing instructions. this should solve your problem
Feb 12, 2010 | Dell Wireless Keyboard Optical Mouse w0147
NO WIRELESS CONNECTION
I am aboutsure about the question, but what i understood is wireless switch location
First close your laptop, then look the front view where the speaker is located, From the left
1.Speakers Left and right speakers deliver stereo audio
output.
2 Power indicator Lights up when the computer is on.
3 Battery indicator Lights up when the battery is being charged
4 Bluetooth communication
button/indicator (for
selected models)
Press to enable/disable the Bluetooth
function. Indicates the status of Bluetooth
communication (optional).
5 Wireless communication
button/indicator
Press to enable/disable the wireless function.
Indicates the status of wireless LAN
6 Line-in jack Accepts audio line-in devices (e.g., audio CD
player, stereo walkman).
7 Mic-in jack Accepts inputs from external microphones.
So your wireless switch is the 5th one from the left. Locate it and turn on the wireless, and try to connet to the router.
Try this, hope it may work,
Jan 27, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
