Recently purchased new fire stick, plugged in to downstairs telly switch on screen goes black amazon comes up on screen then nothing. Took it up to telly upstairs plug it in switch on screen goes black amazon comes up on screen then fire tv stick then works perfectly. Has anyone any ideas as to why it wont work on telly downstairs?
SOURCE: wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house.
2. Press and HOLD the product's own power button for 1 minute to drain the capacitors.
3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and
hold down it's power button. Electricity can remain in capacitors and on circuit boards
enough to prevent normal functionality. By clearing the residue electricity, your product
will have a fresh start and many times this will resolve a buggy or non-responsive device
that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on. The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Posted on Mar 25, 2009
SOURCE: blacks out within seconds of being on the screen
Your monitor has problems with instability in the circuits,This causes error voltages to appear in the feedback circuits and the unit goes into protection mode to protect itself from more damage If you are still under warranty take the unit to a service center for repair. If you are out of warranty, Then you have the choice of fixing it your self, but you must research the problem and have the technical know how to open the monitor and check the circuit boards for the problem. This also requires a certain amount of test equipment. A digital Multimeter and tools to open the case. Plastic pry bars use for furniture work well, or a plastic putty knife to unlock the inside latching around the case.You will also need screwdrivers and soldering iron and a solder ****** or solder wick to remove solder. You need to do this to remove components from the boards to test them. Most likely suspects are capacitors or diodes in the power supply or in the control board. You may need to check transistors and transformers to find more serious problems. There could be a bad IC in one of the regulator or signal circuits. AsYou can see this is not a easy task for a person will little experience and test equipment to check out the problems. You might have a friend who can help you with this who has the experience and tools . If you find you cannot solve these problems, you can either buy a new monitor or take yours to a repair shop for repairs. Hope this helps you out with your problems.
Posted on Apr 28, 2009
SOURCE: hi,
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be.
Hope this will help and Merry Chrismas
Posted on Dec 14, 2009
SOURCE: Fire and Heaters producing soot.
no its not gas it sounds like fumes get them checked over asap the localgas company will check them out for you
Posted on Jan 14, 2010
SOURCE: tv upstairs was working perfect then lost all
If you are talking FREEVIEW. you have to retune it may not automatically retune, were as the other tv's may have auto retune???
Posted on May 12, 2011
Nov 26, 2017 | Computers & Internet
Oct 01, 2017 | Televison & Video
Apr 21, 2017 | The Computers & Internet
Dec 23, 2016 | Televison & Video
Aug 30, 2016 | Amazon Fire TV Stick
Jan 11, 2016 | Televison & Video
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
May 06, 2015 | Computers & Internet
Apr 03, 2015 | Amazon Fire TV Stick
Dec 03, 2012 | Cars & Trucks
Apr 24, 2018 | Roku Televison & Video
46 people viewed this question
