Question about Epson Office Equipment & Supplies
How do i fix my epson printer wf-3620
When i print or copy it picks 1st paper well and print it well bt when it finish pick another 2 papers, one behaves like want to print and stuck at rollers another one stucks at duplex
  • 8637 Answers
SOURCE: Paper stuck
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
  • 61 Answers
SOURCE: Roller no longer picks up paper
Check to make sure that the rollers are not just sliding on the paper instead of gripping it. If this is the case, one thing you can try is to get some rubbing alcohol and cotton swab the rollers to make sure they are clean. Be sure to power down the copier first and unplug it.
Over time, the paper fibers build up on the rollers, and eventually, they get worn out. Cleaning them once in a while can prolong their lives and sometimes even revive "dead" rollers.
Also, let the alcohol dry before you try using the copier again.
Hope this helps!
Posted on Mar 16, 2009
  • 15 Answers
SOURCE: Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Posted on Jun 01, 2009
  • 1684 Answers
SOURCE: paper jam 241.10
The 241.10 error indicates 2 possible problems. First is worn pickup rollers, you said that you flipped them. that should have temporarily fixed the issue. The second option is overfilling the paper tray, try it only half way full and see if it picks up paper and prints. If it still does not pick up paper I would replace the pickup rollers, the turning them inside out trick is only temporary anyway. The roller surface should be rough and have a texture to if not smooth at all. We have the roller kit available if you need one, they run $8.95 shipped. Contact us at the email below if you have any questions or if you need a set of rollers.
I hope this helps, if so please rate our solution.
Corporate Computer
Posted on Dec 09, 2009
  • 150 Answers
SOURCE: Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Posted on Apr 27, 2010
How do I print on 11 x 14 paper? According to the online manual, the Epson WF - 7620 does print 11 x 14. And that is why I bought the printer, but I cannot figure it out!
Load A3 size paper on the lower tray.
Verify you see A3 as an option in paper setuo on the printer screen against tray 2.
Make sure you have selected A3 on the software before you print.
Sep 18, 2016 | Epson WorkForce WF-7620 Wireless Color...
Why won't my Epson WF-7620 print on thick paper when fed from the rear slot
Are you setting the printer to A3 when you hit print? When you select print you will get a on screen box where you can change options and then confirm by clicking print. Most printers are set to default legal size.
Aug 07, 2016 | Epson WorkForce WF-7620 Wireless Color...
Problem with printing, no ink on paper
The print heads are clogged or you are out of ink. Try the steps in the link (Epson support page).
Epson WorkForce WF 2530 All in One Printer
Apr 06, 2016 | Epson WorkForce WF-2530 All-in-One...
Problems with the ADF will not pick up documents
probably not a good idea to try self fixing .and they do have shipping services to send it in like UPS ,FEDEX and others
Jan 23, 2016 | Epson WorkForce WF-2540 All-in-One Inkjet...
Error, paper out, when paper is loaded.
check there is the sensor cable is broken or the sensor is faulty.
Oct 12, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
My epson 710 artisan gives an error message that there is a paper jam or is out of paper, when I try to print a photo, it feeds through 2 blank 4*6 photo papers. There is NO paper jam when I check it, and...
Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
Jul 24, 2017 | Epson Artisan 710 AllInOne InkJet Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
