Winterhalter GS502 error code 18? - Washing Machines
3 Suggested Answers
SOURCE: could you please tell me what error codes 21 and 6
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Posted on Sep 28, 2010
SOURCE: winterhalter gs502 dishwasher-error code 15?What's
The float switch/level sensor in the rinse boiler has not activated. This could be a faulty solenoid not letting the water in(assuming the isolating valve is turned on), or a faulty float switch/level sensor. This would result in water overflowing through the rinse arms and the overflow in the rear of the wash tank.
Posted on Mar 29, 2011
Winterhalter machine code error 24 and 26
its a drain issue. something is plugged or pump isn't working.
Feb 23, 2017 | Washing Machines
What does error code 35 mean on the winterhalter dishwasher
Error 15 = on the GS502/515 is a Main Water Stop Valve Blocked or Closed
Apr 28, 2015 | Dishwashers
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
WHAT DOES ERROR CODE 6 MEAN
I'm thinking the drain is plugged. Good Luck.
Nov 24, 2013 | Washing Machines
Winterhalter gs 302 error Code 15
haw can i chainge a float switch on a winterhalter gs302 ?
please any one can hellp
Mar 17, 2013 | Dishwashers
Error code 23 on winterhalter gs 502
hi i a have a problem with dish washer it shows error 23 .and the ,model is GS 502,GS 515 .So how can i rectify the problem .thanks in advance.
Dec 28, 2012 | Dishwashers
Winterhalter gs502 dishwasher-error code 15?What's mean fault code 15?
Mar 18, 2011 | Dishwashers
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
hope this helps
jarv
Mar 29, 2010 | Dishwashers
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
