SOURCE: cant turn off closed captioning
I have a PME-42S6 on Ebay that has a turning on problem it is a complete unit and work good if you can get it to turn on
Ebay # 120362175465
bid on it and pick it up and there is your remote control
Bob
678-333-6746
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
SOURCE: close caption wont come off
Hello delores2469,
The original remote control for this model had a caption button on it, a few rows up from the bottom on the right hand side. I don't recall this model having the cations option in the menus, but it's been a few years since I sold these. If you do not have the original remote I recommend that you get one. DO NOT ATTEMPT TO USE A UNIVERSAL FOR THIS. You will only be throwing away money, trust me on this. You should be able to obtain an original from a local Toshiba authorized retailer, just not a big box. They can't or won't help you. If you do not have a local dealer, you can search for it on the 'net. There are several remote retailers and most have searchable websites by the model. The original Toshiba remote for this was a WC-5BC1.
Hope this helps you and don't forget to rate the answer,
The Wing Guy
my tv is a element brand . i like to watch closed caption along with the audio because I dont hear very well but no matter what I change in the audio I cant do anything with the audio. its like my whole closed captioning has beenlocked away .
What is the model number of your TV?
