How do i stop my machine from staying in the dryer cycle and turn it back into wash mood
  • David Ellis Rhea May 12, 2017
    Hi agatha nansimbi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please share the year,(?) make, and model of the machine.
    Master:
  • 923 Answers
What controls when you are in the mood to wash, or in the mood to dry? Perhaps the weather, or it's related sounds?
Posted on May 12, 2017
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
First, the machine started to do a strange noise during the cycle. At the end of the cycle, I couldn't open the door because there were too much water in the machine, so it means that the cycle...
Check for a blockage. Or try to buy a washing machine cleaner and put it inside without clothes and run the machine alone. This will help. If it won't then you will need to get a new machine
Nov 11, 2012 | Hotpoint Ariston AWD129 Front Load...
Tumble dryer has stopped working
you can check pump ,if pump isn't working water stay all time .
Feb 20, 2012 | Hotpoint Aquarius WD640 Front Load...
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
My washing machine drain system seems to open intermittently during the wash cycle. the machine stops and water turns back on to attempt to refill the machine to no avail.
mostly your drain hose or stand pipe in wall is to low , loop drain hose up above top of machine, make sure drain hose is only in drain about 6"
Oct 24, 2010 | Kenmore 94702 Front Load Stacked Washer /...
For wd802co the machine is full of water and the cycle is work for wash but when the cycle for rince or spin is comming the selector start tu turn at each cycle and he doesnt stop the water stay in the tub...
have you checked the water pump that draws the water out of the machine there maybe an obstruction like a sock or something. Make sure the pump is turning freely there maybe a blockage there. Also check the exit hose as well. Gain access from the rear.
Aug 23, 2010 | Splendide 2100 Vented Washer-Dryer
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Fisher & Paykel Smart Drive 9- is POKED!!!
hp laserjetm1005 mfp does not get print
Aug 29, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
