Question about Toro Garden
How do you take the head off of a toro 51990A weed wacker
SOURCE: ryobi electic weed wacker
Call Ryboi at 1-800-525-2579. Their part # is Ut41002A-36
Posted on Aug 19, 2008
boscia
  • 163 Answers
SOURCE: weed wacker
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 28, 2008
  • 420 Answers
SOURCE: I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
Posted on May 14, 2009
SOURCE: Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
Posted on May 18, 2009
#1 Taper
  • 1041 Answers
SOURCE: How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
Replace head on toro model #51954 curved shaft trimmers
https://video.search.yahoo.com/yhs/search;_ylt=AwrTcdIyalFXg.QAUmAnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Toro+Model+51954+Weed+Trimmer+Owner+Manual&fr=ytff1-msgr&hspart=mozilla&hsimp=yhs-006
Jun 01, 2016 | Toro Garden
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
Have a toro 51940 model gas weed wacker that just won't start. What's the most common reasons? I replaced the spark plug already!
Check and clean the air filter. That's always been my problem. Wash/dry add a drop or two of oil and work it in.
May 07, 2011 | Garden
I have a craftsman pro series gas weed wacker and I need to know how to change the head to put a universal cutting attachment on
Very easy. There is usualy only one nut to undo.
You need to grip the head somehow, to stop it turning, and simply undo the nut with a suitable socket wrench. From my experience, most of the nuts on weed wackers are left hand thread, so to undo the nut, turn it clockwise.
Jun 14, 2010 | Garden
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Sears Weed Wacker Line trimmer trouble starting, then stops after a few seconds.
hi
how do u remove the head assy on 13" toro rimmer?
plz help
tx
Sep 08, 2009 | Craftsman Garden
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
